11-28-2018, 08:37 AM | #1 |
Drives: 2016 Chevy Camaro SS Join Date: Feb 2016
Transmission filter
Is the transmission filter accessible by just dropping the pan? Auto car
11-28-2018, 10:41 AM | #2 |
Drives: 2017 Camaro SS 1970 chevelle SS Join Date: Oct 2016
Yes. Same as other GM trannys. The pan gasket is also reusable if not damaged.
Be aware- it is a total PITA to try and refill the trans fluid through the fill hole on the side in the Camaro. If you could find the filler tool that they use at the dealer, then it would be simple. Drop pan, clean, change filter, replace, remove fluid level check plug and attach filler tool. you'll need some sort of fluid transfer pump if you use this method. I cant really get my hands up into the side of the tranny to get to the fill plug. if you have small hands/arms, you may be able to more easily refill the trans. |
11-28-2018, 11:51 AM | #3 | |
Drives: 2017 2SS Convertible Join Date: Apr 2017
You wouldnt happen to know the part number for this tool? Guessing its one of those expensive as hell Kent Moore tools ?
2017 2SS, Hyper Blue, 8sp, NPP, MRC |
12-02-2018, 09:18 PM | #4 | |
I believe it is a DT-51190. And yes, Kent Moore. They are proud of it, lol. Around 40-50 bucks; it’s what my dealer used when they did the triple flush in my car way back. If I ever feel the need to do it again, I will buy one. The side fill hole may be easy to get to in the trucks, but it was very annoying to try to do In my SS. I don’t get why they won’t just put a a damn dipstick on theses newer transmissions. Sent from my iPhone using Tapatalk
2017 camaro SS A8
FBO With all porting and tuning done by PRAY |
