Old 10-18-2018, 09:57 PM   #1
Baddawg53
Drives: 17 hyper blue 2SS M6
SS M6 shifter upgrade hurst or gm?
I’ve read a lot of threads discussing the quality of the stock shifter. I really don’t have an issue with it, but my car is my hobby and I like working on it.
I’ve pretty much decided my next mod will be a short throw shifter, I am looking for feedback from anyone who has changed their SS to a hurst or GM short throw. I want to retain the factory appearance, so both these options will work for me. If you’ve upgraded it, what do you think about the performance?
Baddawg53 is offline   Reply With Quote
Old 10-18-2018, 10:15 PM   #2
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I've felt the 1le shifter.... Hands down, I would go Hurst again and again
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 10-18-2018, 10:27 PM   #3
Baddawg53
Thanks... Exactly the type of advice I was looking for ...
Old 10-18-2018, 10:42 PM   #4
Dubchitts
Dubchitts's Avatar
There's a few threads that have a few opinions on the subject. Everyone who has the Hurst loves it from what I've seen. Very Short throw, feels great etc. If you're trying to fix the 2nd gear notchiness, that's solved with a fluid change.
Gm throw reduction 6%
Hurst throw reduction 40
"Spitfire" 427ci
Old 10-18-2018, 10:51 PM   #5
Baddawg53
I tried the fluid change, and I saw no difference in the notchy shift to 2nd. I figured out if I move the shifter to neutral and come back to 2nd it is smooth, so that’s generally what I do when the tranny is cold. Just takes longer to shift.
I think installing the shifter will be a decent weekend project, it seems fairly involved for a shifter. I have no real reason for doing it other than I just want to. Just want to make sure I put the right one in the first time.
Old 10-18-2018, 11:10 PM   #6
Dubchitts
Dubchitts's Avatar
What fluid did you put in
"Spitfire" 427ci
Old 10-18-2018, 11:21 PM   #7
Baddawg53
I wanna say it was red line?? Been a while since I did it, like a year. Synthetic, got rave reviews here on this forum. So that’s why I went that route.
Old 10-19-2018, 03:33 PM   #8
retmil
Drives: 2022 Wild Cherry SS
Do not mean to hack the thread but I recently replaced the trans fluid in my 17SS with Royal Purple and the issue with the 2nd gear notchiness has not improved.
retmil is offline   Reply With Quote
Old 10-19-2018, 03:46 PM   #9
Baddawg53
You're good man, conversation goes where it goes ...
Like I said, my only way around it is to bring the shifter into the middle, between 3 & 4, then over to 2nd. Then it falls right in.
Old 10-21-2018, 07:33 PM   #10
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
On the SS models, GM quotes a 8.75% reduction in throw with the 1LE shifter, while Hurst advertises a 40% reduction in throw. The Hurst / stock knob setup sits a little higher (than their white knob setup) and I measured the throw reduction to be 34.4% shorter than stock.
OP, my feedback on the Hurst shifter / stock knob setup is here: https://www.camaro6.com/forums/showthread.php?t=521320
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 10-30-2018, 04:30 PM   #11
asthmamax11
asthmamax11's Avatar
I recommend the Hurst. I've had 5 different short shifter between my C5/Trans Am and this Camaro. This Hurst feels the most like OEM except shift throws are significantly reduced. I have the pistil grip which i feel helps as well.
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-31-2018, 09:11 AM   #12
RDBURNR
RDBURNR's Avatar
Drives: 2016 Camarro 2SS
I recently had the OEM knob Hurst short throw shifter installed, a very notable decrease in travel, a bit notchy though and I wish it was a bit smoother.
______________________________________
2016 2SS
P1SC-1 Procharger
Stage 2 Intercooler w/ Race BOV
ZL1 Fuel Upgrade
LT4 Injectors
Fuel Voltage Booster
AEM Boost and AFR Gauges
Dynatech 1 7/8th Headers
JRE Tuning
RDBURNR is offline   Reply With Quote
Old 11-01-2018, 09:22 PM   #13
Baddawg53
I installed my hurst with factory knob on Sunday. The install sucked but I really like everything about the shifter and the performance, the shifts are quick and precise. It’s definitely up there with the best mods I’ve done on my car.
Old 11-19-2018, 04:19 PM   #14
blk 2013
blk 2013's Avatar
Drives: 2017 SS 6sp
yes
blk 2013 is offline   Reply With Quote
