Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > CANADA
Old 10-06-2018, 02:00 PM   #1
Mstrblue
Mstrblue's Avatar
Drives: 2018 Camaro SS Redline Summit White
Tpms Question
Does any one know what are the effects of not having TPMS ? I am looking at getting a winter tire step up and wondering if I am only going to have to look at the light or is there an alarm or would it effect the car driving modes.?
Maybe I am just being cheap😀 and should just get the sensors. Thanks
Mstrblue is offline   Reply With Quote
Old 10-06-2018, 10:56 PM   #2
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
doesn't affect modes or anything else. my winter setup doesn't have tpms.. its the dash tire light light that stays on.....
and centre screen warning you dismiss each time u start the car.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 10-08-2018, 08:38 AM   #3
Mstrblue
Mstrblue's Avatar
Thanks so much ����
Old 10-08-2018, 09:16 AM   #4
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I 2nd this. No issues other than a TPMS notification.
The upshot is in springtime when you put the main tires back on, the TPMS sensors are already paired and you don't have to do anything but put them on.
Old 10-08-2018, 09:28 AM   #5
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I'd get the sensors. These days you can clone them so you don't need to reprogram 2x/year.
Old 10-08-2018, 09:57 PM   #6
dunedon
dunedon's Avatar
Drives: 2018 Hot Wheels 2SS Convertible
Wonder if my tire guy knows this ... Just got new winters with TPMS ... Putting them on after next week's heat wave is over. Would make life simpler for both of us
2018 Hot Wheels SE, Convertible, V8, 2SS, A8, MRC, Nav, NPP (WDXNTP)
1100 - 28/05/18 | 2000 - 31/05/18 | 3100 - 05/06/18 | 3400 - 15/06/18
.TPW - 16/07/18 | 3800 - 16/07/18 | 4300 - 17/07/18 | 4200 - 24/07/18
5000 - 25/07/18 | 6000 - 31/07/18 | XPEL - 01/08/18 | HOME - 13/08/18
dunedon is offline   Reply With Quote
Old 10-08-2018, 10:34 PM   #7
How do you get this done? I'm purchasing a second set tomorrow.
Old 10-08-2018, 10:52 PM   #8
DaveC113
DaveC113's Avatar
Good timing... I just dropped off my winter tires and tpms sensors at the shop to get them mounted on new wheels and we went through the cloning process.
The tech at the tire store read the sensors on my car with a scanner, then held the new tpms sensors near the scan tool one by one and it cloned them. After install you'd need the scan tool again if you want to get the positions correct, but you'd have to do that after a tire rotation anyways.
I got a basic programming tool with some lugs, locks and tpms sensors from a member here. I haven't used the programmer yet but there's only one button so I assume you hold the tool near the valve stem and press the button one by one. This may also work if the tpms sensors weren't cloned, idk...
Old 10-09-2018, 08:40 AM   #9
Thanks for the info. I was just going to buy the tool and do it myself but now I think I'll keep the sensors in hand to make cloning easier. I don't have a square setup so only possible rotation will be side to side if that happens.
Old 10-09-2018, 10:09 AM   #10
DaveC113
DaveC113's Avatar
I'm not clear on the difference between cloning and using the single button programmer. I assume if cloned and the wheels are put in the same position the programmer won't be needed at all. I went square for winter and am going to use 7mm spacers up front so the rears don't stick out past the stock 305s. That way I get my full 30k mile warranty on the PA4s, lol...
