09-28-2018, 08:29 PM | #1 |
Drives: 2017 camaro SS 1LE Join Date: Jan 2017
Manual to TH400 swap
Anyone done this swap? I am about to attempt it. Already purchased the trans, converter, and flexplate. I know someone who went from the A8 to a TH400 but not from a M6. Just looking for some insight as to how difficult it was and such. Mine is a manual valve body so shouldn't be too crazy.
2017 1000+hp Camaro SS
88/96 single turbo manual to TH400 swap 15" conversion Port injection 22K+ followers on Instagram @Sixgunsled 6.4K subscribers YouTube: Sixgunsled |
09-28-2018, 10:03 PM | #2 |
Drives: Camaro 17 SS Join Date: Jan 2017
I think you're the first bro. Things that I can think of that may be a problem would be a way to get speed output data, and possibly issues with torque management. On anouther note, how do you like that hood?
09-29-2018, 04:56 PM | #3 | |
Secondly I am purchasing a module to plug into the clutch sensor that tricks the computer into thinking the stock trans is still there. There isn't a whole lot of torque management with the manual anyway but the module will take care of the rest. I know I'm not the first TH400 swap but not sure if I'm the first manual guy to do it.
09-30-2018, 03:32 PM | #4 |
Liking the sounds of that. Keep us posted
09-30-2018, 09:59 PM | #5 | |
10-01-2018, 06:36 AM | #6 |
Our white Magnuson Camaro has already done the swap. Its a lot of work and cost, so many changes to the drivetrain to make the swap.
10-01-2018, 07:23 AM | #7 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Since you have a 1LE, you also have eLSD, so being able to marry a TH400 with that and the 3.73 rear might be a challenge.
I have wondered about swapping to a a10, but everyone on the forum seems to think that would be too costly.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
10-02-2018, 03:45 PM | #8 |
If you pull the manual pedal assembly lmk
Rotofab, PRAY IM/TB, SE 1 7/8 longtubes full system, SM FLEX FUEL KIT, Custom Exhaust, Mishimoto Catch can, FBO, street tuned.
10-21-2018, 07:21 AM | #9 |
Yes the manual pedal will be coming out
10-21-2018, 07:22 AM | #10 |
The trans will just marry to the drive shaft which will marry to the rear. should change anything. It will bolt right up to the 3.73
10-21-2018, 07:23 AM | #11 |
So far it really hasn't been as costly as I thought. Can you shed some light on what challenges you guys ran into? As well as what parts you used, i.e. what trans cooler are you guys using?
10-21-2018, 07:30 AM | #12 |
Ok guys the flexplate came in the mail a few days ago. Still waiting on the converter and trans which should ship in the next few days. I will be dropping all my motor stuff off at the machine shop monday to get balanced for the new internals.
What I have got so far: 1200hp rated TH400 with LS bell and trans brake, PTC torque converter, and flywheel purchased all together - $3730 shipped Transmission mount - $40 Computer mondule - $200 Hurst quarter stick shifter - $348 Things I still need: Driveshaft and yolk - $350 Transmission cooler - $??? The trans is a reverse manual valve body so I will still be shifting gears which I like. I also have to decide how I am going to monitor my speed. Probably do a wheel speed sensor or get the driveshaft RPMs so my speedometer gauge will still work.
10-21-2018, 09:37 AM | #13 |
Is this going to be a dedicated race car or will you drive it on the street also?
10-21-2018, 12:43 PM | #14 |
And to add on: Are you planning to road course race the car since it is a 1LE or are you focusing only on drag racing?
