07-31-2016, 12:59 AM | #1 |
Convertible Issue
1st issue with my vert. The plastic cover that covers the top's mechanism will not close all of the way. I will make an appointment with a dealer's service department. Anyone else seen this issue?
07-31-2016, 01:24 AM | #2 |
I was asked to post what it should look like. Passenger side works fine. Driver side has an issue.
07-31-2016, 09:04 AM | #3 |
Drives: 2LT, Blue Velvet, Kalahari, Convert Join Date: Feb 2016
I noticed on mine that one side (the passengers) was not as smooth as the other so I put some white lithium grease in the groves and worked it manually back and forth a few times. Now it is smooth as silk. It is a heavy duty plastic on metal kind of deal and needs that lube to avoid binding.
If you look closely, it seems that the factory didn't put quite enough lube on there to begin with.
2LT, RS, V6, A8, Vert, Blue Velvet, Kalahari, Split Silver rims, Convenience & Technology pkgs
07-31-2016, 11:43 AM | #4 | |
07-31-2016, 03:10 PM | #5 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Is that part sensitive enough where it would push down if someone sat or leaned on it? I'm trying to get educated before mine gets here.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
07-31-2016, 03:14 PM | #6 |
As a matter of fact, I was leaning into the backseat from outside the car, with the top down and inadvertently rested my hand on it and it did go down about half an inch and out of track.
I managed to manipulate it back into position. These flaps appear to be subject to variations in build clearance. On my car the one on the drivers side operates very smoothly while on the other side it is a tighter fit. That is why I lubed both to make sure they don't bind.
08-01-2016, 11:04 PM | #7 | ||
08-02-2016, 07:42 AM | #8 |
Drives: 2016 2SS Convertible Join Date: May 2012
The passenger side cover on mine got jammed a while back and I was able to carefully work it back into the track. It's been fine ever since then.
08-16-2016, 08:09 PM | #9 |
Drives: 2016 2SS Garnet Red Convertible Join Date: Feb 2016
Same issue here
My driver side has been doing the exact same thing. I haven't taken it in yet since it's not critical. Was your dealer able to fix easily?
2016 2SS convertible, garnet red, black interior, MRC, NPP, black bowties, low gloss black wheels
Ordered 2/4/16, built 3/9/16, delivered 4/20/16 |
08-17-2016, 01:33 PM | #10 |
Drives: 2017 RS convertible Join Date: May 2009
any results to post on the original issue, RallyHT?
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250 1970 Camaro 2010 2LT RS 2013 2SS RS Current ride: 2017 Camaro 2LT RS convertible |
08-24-2016, 11:47 AM | #11 |
Drives: 2016 Camaro 2SS Convertible Join Date: Dec 2013
My driver side sticks also. But all I have to do is push on it lightly and it closes. Will get it looked at when I take it in for service or another issue.
08-26-2016, 08:43 PM | #12 |
Drives: Fifty 2SS Vert Join Date: Dec 2009
Same issue with mine on the passenger side.
Putting the top back up makes some noise and will not go in the track properly without some help. Will be making an appointment at the dealer |
09-03-2016, 12:08 PM | #13 |
Drives: 2016 Convertible 2SS Join Date: Jun 2014
Be careful with those covers. My daughter was sitting in the back and leaned on the cover. I didn't notice it was pushed ajar before putting the top back up. If those are pushed down or not flush before closing the top, the mechanism will bind and parts break. Mine broke the metal hinge that the door attaches to along with bending the attachment point. Dealer replaced the parts and all is well now...just something to watch. Having lithium grease on those moving parts certainly is a good idea for maintenance and prevention as well. I do really like how the top works and folds in with the hard cover to look so clean compared to Gen 5s as well as the Mustangs.
Vert - 2SS, NGM, Kalahari, Grey wheels, NPP, MRC, NAV, A8
1100 2/22 6000 4/9 |
09-04-2016, 06:53 AM | #14 |
Drives: 2016 Camaro 1LT 2.0T Convertible Join Date: Aug 2016
I just did that today, I kind of just forced the gap open a little more with my bear hand and just popped it back up with a little force. Works perfectly now.
