01-25-2023, 10:09 AM | #1 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Spark plug wire differences
So I have a set of wires that have 140-150 ohms. The stockers measured 1400-1500 ohms. I'm wondering what difference, if any, I might notice if I went with Granatelli's 0 ohm or Texas Speed's 30 ohm wires. Big difference in the money, but I will say Granatelli did back to back dyno tests showing several Camaros/Corvettes and the gains were significant (assuming they didn't play any dyno tricks). Other wires I've seen are Fast Firewires at 25 ohms and Dragon Fire Race series.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
01-25-2023, 10:59 AM | #2 |
Here it comes
01-25-2023, 01:24 PM | #3 |
Shifts under load
I'm not going to bash another manufacturer, but one set dropped my gas mileage 2mpg over several tanks. I'm wondering what difference the resistance of the wires really makes. I'm not an electrical engineer, but I do know it has to have some effect on the performance of the ignition system. I've seen spark plugs cause some cars to run like absolute crap, switch back to the ones that came in it and everything is fine. It's pretty hard to have the time to do back to back dyno runs and swap them out unless your friends owns a dyno.
01-25-2023, 02:13 PM | #4 |
Drives: 2023 2SS Convertible Join Date: May 2009
I always like MSD because you could put a little bend in the boot when you have headers.
-Geoff
01-25-2023, 02:37 PM | #5 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
01-25-2023, 03:13 PM | #6 |
MSD seem to be problematic these days.
Granatelli, Speed Engineering, Stock all work fine. The main factors is heat resistance and durability. No gains otherwise in wires that are a foot or less in length.
2016 NFG 1SS A8
01-25-2023, 03:27 PM | #7 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
I returned my MSD wires to Wildhammer. The ones they show on their site for MSD are only 10" long and do not work if you have headers. You really need a 12" set like the stock ones if you have headers. They recommended TSP wires, but I ended up staying with stock for now, as my knowledge about gains with changing out spark plug wires is nil..
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
01-25-2023, 03:29 PM | #8 |
Shifts under load
Thanks. I have fiberglass "heat socks" on mine.
01-25-2023, 04:41 PM | #9 |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
Resistance is not a useful metric in determining spark plug wire performance...
Quoted from Magnacor... What is not generally understood (or is ignored) is that as a result of the laws of electricity, the potential 45,000 plus volts (with alternating current characteristics) from the ignition coil (a pulse type transformer) does not flow through the entire length of fine wire used for a spiral conductor like the 1 volt DC voltage from a test ohmmeter, but flows in a magnetic field surrounding the outermost surface of the spiral windings (skin effect). The same skin effect applies equally to the same pulsating flow of current passing through carbon and solid metal conductors. A spiral conductor with a low electrical resistance measured by an ohmmeter indicates, in reality, nothing other than less of the expensive fine wire is used for the conductor windings — a construction which cannot achieve a clean and efficient current flow through the magnetic field surrounding the windings, resulting in poor suppression for RFI and EMI. |
01-25-2023, 04:45 PM | #10 |
Sorry, we’ve already had our weekly “best spark plug thread” a few days ago so time to close this one down.
01-25-2023, 04:46 PM | #11 |
Shifts under load
That's what I was trying to figure out. Thanks a bunch! I am looking at high temp wires with suppression for RFI and EMI.
01-31-2023, 03:27 PM | #12 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
I have the GPI wires, made by Scott's I believe, and they fit perfect with headers. Just the right length with plenty of clearance, 45 degree boot angles on both ends, thick insulation, and 30 ohms rated. Also you can get then in the color or your choice.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
01-31-2023, 03:44 PM | #13 |
Shifts under load
Thanks, I will look at those and Texas Speed’s.
01-31-2023, 06:03 PM | #14 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
I really like the performance of the gpi wires. I went back to stock for a test and got many misfires. Put the gpi back on mis fires gone. The fit is perfect as well for headers. My headers are coated.
