TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Autos For Sale / Wanted
Old 12-31-2015, 12:17 PM   #1
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/ ctsv3
Fully Built 2012 Camaro IOM Price drop
Ive decided to sell my Camaro, I have put a lot of time into this car and when you see it.. it shows.
The car has almost 13k miles on it right now and only almost 3k miles on the new fully built motor, below is the list of modifications I have done yo the car
TMS ( Thompson Motor Sports ) LSX 418 c.i. 10.1 compression Rated For 1500hp
4.000'' crankshaft
Thompson motorsports 6.125" connection rods
Diamond Pistons
Performance file fit ring set
King racing narrowed rod &main bearings
GMPP cam Bearings
Arp main studs
Arp head bolts
Melling high pressure oil pump
Prc 260 6 bolt heads with ls9 head gaskets
Brian Tooley rocker Arm Turnion Upgrade
Brian Tooley Pushrods
C5 R timing chain
ls2 chain dampener
Custom Ground Turbo Cam 235*-244*-118 +4* .638” .622”
Stock ls3 intake with Nasty Nate Fuel rails
129lbs Fuel injectors
Lokar Oil dip stick
Mcload RXT clutch with remote bleeder
Ideal Garage modified clutch slave cylinder
MGW Full replacement shifter with 2013+ shift knob
Improved Racing Dynamics 180degree oil cooler block with added Mishimoto 19 row aluminum oil cooler
Fore Innovation Level 4 dual fuel system ( 2 Walbro 450's ) with -8an feed and -10 return fuel lines and reusable fuel filter
DeWitt's high performance aluminum direct fit radiator
RX color matched catch can
Pro Sport A/F and Boost gauge with pillar pod
Poly motor mounts
Texas speed 2 inch into 3inch long tube headers
Kooks full 3 inch exhaust header back no cats
Pedders supercar coil overs
Pedders steering rack bushings
Pedders radius rod bushings
Pfadt trailing arms
Pfadt Solid rear sub frame bushings
JP Superior Solutions rear sway bar
ZL1 Front 6 piston Brembo brakes ( front and rear calipers have been professionally powder coated )
Gforce engineering 1320 bolt in 9inch irs kit with 3:70 gears
Forgeline 3 piece GX3 20" Rims 275 front Nitto Invo's 315 rear Nitto Nt05r's
Oem ZL1 hood with painted carbon fiber insert
Daytime driving lights have been replaced with projector sytle to match the headlights and added 5k hid's from Diode Dynamics
Color match bowties and tail light bezels
Sequential LED Rear Lamps with Rapid Fire and Afterburner
Also under the hood as been completely wire tucked and cleaned, I was planning on doing a custom top mount twin turbo setup, ecu and fuse box has all been safely relocated under the cowl by the cabin air filter area. The engine harness has also been modified, originally it would run from the back of the passenger side down to the front of the engine and cross over to the drivers side and run back down.. To clean it up I made the harness run from the back and both sides run down to the front to keep the loom form crossing the front of the engine bay to give it a nice clean appearance. When the original motor was removed the ac system stayed in the car so the factory freon did not escape the system and the ac is still as cold as it was when I bought the car
Car has been Tuned and everything went over by JMS after engine install and wire tucked
it was dyno tuned and made 505whp
The car has been a weekend or once a week to work car, I built the car to take it to the strip but never taken it. the car has been well taken care of, looks and smell brand new inside and out.. Always been in a garage with a car cover when not being driven, I wipe it down every time I drive it and never leave it setting dirty also never been purposely driven in the rain but I have been caught in the rain once or twice.
Not looking for trades
I know there are a lot of Camaros for sale with more power but most are just an added SC or turbo kit, non have a fully built motor, rear end suspension, fuel system ect.
If you have any question or want more pictures ( I have a ton ) feel free to PM or text me if you are serious about purchasing, if your not then not to sound like an ass but please do not waste my time.
40k
2012InfernoSS is offline   Reply With Quote
Old 01-03-2016, 07:15 PM   #2
CrazyTurbo98TA
Drives: 1998 WS6 441 LSX
MAY GOOD LUCK WITH SALE BEAUTIFUL CAR! I WANT IT!
1998 25.2 jet stream blue metallic Trans/Am KFP Racing
2001 procharged ws6 408/f1-A KFP Racing
2012 ram 3500 dually triple black cummins 24" American force
2013 ZL1
1993 FOBRA MUSTANG 427 LSX TWIN TURBO/4L80 BUILD
CrazyTurbo98TA is offline   Reply With Quote
Old 01-03-2016, 09:38 PM   #3
pdiddy
Drives: 2011 2SS
Where did U move the abs module to it looks very clean now I am considering moving my fuse box also I love how clean it is when it's done
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 01-04-2016, 06:35 PM   #4
2012InfernoSS
Thank you sir
Old 01-08-2016, 07:07 PM   #5
2012InfernoSS
ttt
Old 01-15-2016, 08:59 AM   #6
2012InfernoSS
TTT
Old 01-22-2016, 03:30 PM   #7
2012InfernoSS
bump
Old 02-21-2016, 01:28 PM   #8
2012InfernoSS
ttt
Old 03-23-2016, 03:08 PM   #9
2012InfernoSS
TTT Price drop 45k
Old 03-27-2016, 07:34 AM   #10
2012InfernoSS
ttt
Old 04-13-2016, 11:19 PM   #11
2012InfernoSS
To the top
Sent from my ONE A2005 using Tapatalk
Old 04-18-2016, 03:45 PM   #12
2012InfernoSS
Still for sale
Old 04-21-2016, 02:40 PM   #13
2012InfernoSS
TtT
Old 04-24-2016, 03:45 PM   #14
2012InfernoSS
Added a new braille 18lb battery and some light weight chromoly crash supports.
