Old 07-15-2021, 03:39 PM   #1
cajunzl1
Drives: 2018 ZL1
Will I run out fuel ? IF
Currently have a Rotofab and Ported TB, going to add the following:
Kong Port job with 2.3 Pulley, and E85 Sensor. Can i run a mixture like E60 and still have enough fuel pressure?
Thanks
cajunzl1 is offline   Reply With Quote
Old 07-15-2021, 03:42 PM   #2
atljar
Drives: C7 Z06
No you wont have enough fuel for E60
The 'Cooler Bleeder - www.coolerbleeder.com
Fully automated CAC / intercooler bleeding system
2015 Corvette Z06/7 - Mods in progress
2006 Corvette Z06 -Bolt ons + Darin Morgan heads Sold
1997 Corvette - Baby cam and bolt ons Sold
1994 Camaro Z28 - 383/AFR's/Single Plane Sold
atljar is offline   Reply With Quote
Old 07-15-2021, 06:28 PM   #3
NOVAtwinLS3
NOVAtwinLS3's Avatar
Drives: 2018 ZL1
I asked Complete Street Performance same question have mods similar to you, they said it’s a no go.
CSP 755 Package. 2” headers, Kong ported blower, NW103mm TB, RF Big Gulp, Mighty Mouse catch can.
630rwhp/660rwtq.
NOVAtwinLS3 is offline   Reply With Quote
Old 07-15-2021, 07:23 PM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Thanks
Scratch the pulley. Should be able to run e-50. Take a look at teds package.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 07-15-2021, 08:53 PM   #5
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Add a JMS booster and then your tuner can test to see how much e you can blend. I’d guess e40-e50. I’m on e70
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
CW3SF is offline   Reply With Quote
Old 07-15-2021, 08:57 PM   #6
cajunzl1
Drives: 2018 ZL1
Thanks, but starting to realize the E85 stations are scarce in my area, just a few nearby have E15 only.
May just stick with a port and pulley...
Old 07-15-2021, 09:20 PM   #7
Markoz28
Drives: 18 ZL1 nightfall grey A10
Add headers to the mix. Makes a big difference.
Markoz28 is offline   Reply With Quote
