06-09-2023, 07:23 AM | #29 |
Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
I found it to be a little brutal. Didn't like that at all.
06-09-2023, 07:33 AM | #30 |
That's unfortunate, perhaps the 2019+ tune is different and more aggressive... IMO performance shift mode is one of the saving graces of the automatic, a true source of enjoyment.
06-09-2023, 08:21 AM | #31 |
06-09-2023, 08:30 AM | #32 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Sticky tires and competition mode is most practical setting for rolling pulls
I saw a 6th gen crash into a wall on highway last week trying to show off "cutting up" Dumbass probably turned off everything Happened 15 feet in front of me i had to swerve to avoid him
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
06-09-2023, 08:43 AM | #33 | |
06-09-2023, 10:11 AM | #34 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
ESC Competitive mode: Does NOT turn off stabilitrak, but turns off everything else
Holding the button down for 10 seconds turns EVERYTHING off, including stabilitrak. It's those jackasses that crash into walls because they failed basic physics. You don't keep on the gas pedal when you fish tail you let off. Stabilitrak keeps your car going straight. I use ESC Comp mode at the strip every time I go. I used to run with all nannies turned off but I found my best runs are with ESC Comp On and Stabilitrak enabled. Quote:
Performance shift is used best during roll races, as it allows the car to down shift automatically to the lowest gear possible relative to speed. It then holds that gear for 7 seconds, and you have to put the car in Manual Mode if you want to hold that gear longer than 7 seconds. Then put the shifter back into drive the moment you hit the gas to take off. Not doing so results in a lost roll race most of the time.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
06-09-2023, 10:35 AM | #35 |
Thanks FlukeSS
06-09-2023, 10:40 AM | #36 |
"It's those jackasses that crash into walls because they failed basic physics. You don't keep on the gas pedal when you fish tail you let off."
EXACTLY
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
06-09-2023, 11:01 AM | #37 |
Also the conditions where Performance Shift Mode engages automatically are as follows:
1. Hard acceleration pull 2. Hard Braking (near panic braking conditions) 3. Hard cornering (Track Course) To manually engage Performance Shift Mode: 1. Slam the gas pedal to the floor as quickly as possible and let off immediately
06-09-2023, 11:18 AM | #38 |
Also you have to be in Auto mode not manual, correct?
2022 Black ZL1
06-09-2023, 11:19 AM | #39 |
Drives: 2SS 1LE Join Date: Oct 2011
And Mustangs.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-09-2023, 01:47 PM | #40 |
To engage Performance shift, have to be in drive so yes auto. Once engaged then you can switch to manual to hold the gear it goes in and/or use paddle shifters if you must.
06-09-2023, 01:51 PM | #41 | |
Pedestrians don't count
So this is more for the Dodge guys.
06-09-2023, 01:58 PM | #42 |
