Old 01-20-2019, 10:42 AM   #1
Team141
Team141's Avatar
Drives: 2016 Camaro 2SS M6
Question Open Hood Latch = Dead Battery
I’ve scoured the internets looking for a schematic or definitive answer, but can’t seem to find any supporting data on this subject.
Question: If you leave your hood up (in the heated garage), for say a week while working on cosmetics, will the latch switch/sensor recognize that the “hood is open” and not allow the computer to go to sleep fully? Never had an issue w my battery when car sits for weeks at a time, until I left the hood open. I’ve since charged the battery and it tests fine, so the battery is not bad. I’ve also set the latch into the “latched” position, and I’ve seen no voltage drop (draw) over the past 2 days.
Just curious! Thanks in advance!
-Chad
Last edited by Team141; 01-20-2019 at 12:03 PM. Reason: Changed title to describe better
Team141 is offline   Reply With Quote
Old 01-20-2019, 07:20 PM   #2
franksredhot
franksredhot's Avatar
Drives: 2016 Red Hot Camaro 1SS A8
I leave my hood open with a battery tender hooked up. I noticed that my battery would weaken if I don't drive for a couple of weeks. Get the Tender Jr. I picked one up for $25. For just a trickle its good enough.
franksredhot is offline   Reply With Quote
Old 01-21-2019, 01:00 AM   #3
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
I leave the hood up sometimes after taking a drive, I will put the battery tender on and the tender goes into standby about the same time frame as when I leave the hood down. I don't think that it matters. It will be interesting to see feedback on this
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 01-21-2019, 03:24 PM   #4
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
Originally Posted by Memphis SS View Post
I leave the hood up sometimes after taking a drive, I will put the battery tender on and the tender goes into standby about the same time frame as when I leave the hood down. I don't think that it matter. It will be interesting to see feedback on this
I do the same.
Magnum922 is offline   Reply With Quote
Old 01-21-2019, 08:38 PM   #5
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I had my car sitting in the garage for a week with the hood up while I was installing the RS headlights. The car died on the 7th day but I don’t think it was the hood. It did start and stay with enough juice throughout the days though
Old 01-22-2019, 12:36 PM   #6
zag
Drives: 2018 camaro 2 ss
Could you please post a pic where this sensor is located?
THANKS
zag is offline   Reply With Quote
Old 01-22-2019, 07:12 PM   #7
GroundhogSS
GroundhogSS's Avatar
I have heard/read that leaving the hood up is hard on the gas cylinders in the hood supports. They shouldn't be left in the extended position. Not sure it that is true. When I have the battery charger connected, I just prop the hood up a little with a spray paint can.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 01-22-2019, 11:17 PM   #8
STEVE41
Drives: 2016 SS
i leave my hood open when ever i am not driving it. sometimes i don't start it for like 6 days straight and never had a problem. not even sure if leaving hood open will drain the battery or not.
STEVE41 is offline   Reply With Quote
Old 01-23-2019, 05:33 AM   #9
Jhunsberger
Jhunsberger's Avatar
Drives: 2017 Camaro 1SS M6 (SOLD)
Last week i switched over my battery tender to the Camaro, with the hood popped but not open. Last time i had it out a few weeks ago, it was slow to start. After 3 days the tender is in stand by mode. Doesnt really answer the questions, but just my current experience.
Stock: 416hp/427tq, 12.21 @ 116.80
Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft.
Tuned by EFX Tuning 688hp/632tq
Best 1/4 to date: 10.705 @ 131.92
Jhunsberger is offline   Reply With Quote
Old 01-23-2019, 12:01 PM   #10
Team141
Team141's Avatar
Sorry for the delay, but thank you for the info. Great info out there on Transport Mode, as well as the suggestions for a Battery Tender. I’ve gone ahead and picked one up and plan to install it this weekend.
Before I install the Battery Tender, I’ll be doing a few tests, as well as a Parasitic Draw Test. I’ll be sure to focus on the Hoodlatch Switch and it’s corresponding Circuit/Fuse. The engineer side of me has my curiosity peaked. I’d be willing to bet that the switch/sensor does in fact cause issues with the car not being able to go completely asleep. Time will tell based on the mA/A Draw recorded. I’ll be sure to post my findings.
For the user that wanted to see pictures of the latch/switch location, I’ll post those as well.
Thanks!
Chad
Old 01-23-2019, 03:49 PM   #11
zag
Thanks for posting the pics. Peoples follow through is one of the things that make this forum great.
Old 01-23-2019, 05:49 PM   #12
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Originally Posted by Team141 View Post
Before I install the Battery Tender, I’ll be doing a few tests, as well as a Parasitic Draw Test. ...
I believe the electronics go through stages of shut down and sleep, so when you check the parasitic draw, the amp draw will change over time. I don't know any details, so if you could provide some findings from your tests over time it would be greatly appreciated!
17rsvert is offline   Reply With Quote
Old 01-23-2019, 11:39 PM   #13
GroundhogSS
Thanks for doing these tests. Looking forward to the results.
Richard
#TeamBeckyD
Old 01-24-2019, 10:47 AM   #14
Fatty1707
Drives: 2019 ZL1 A10
My zl1 came with a factory charger and seems to work. I have 4 others from "battery tender" that work great for many years.
Fatty1707 is offline   Reply With Quote
battery draw, hood latch
