Old 10-25-2017, 06:34 PM   #15
Moyda23
Moyda23's Avatar
Drives: 2017 Camaro 2SS Red Hot Coupe
I just realized the winter tires I bought are all the same size, whereas my stock tires are different in the rear. Will that matter much. All 4 winter tires are 245/40R20 95V. The front stock tires are 245/40ZR20 95Y but the rears are 275/35ZR20 98Y.
Moyda23 is offline   Reply With Quote
Old 10-26-2017, 03:42 PM   #16
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
You can run the 245's on all four corners. It works fine for a winter setup.
Rudy@Tirerack is offline   Reply With Quote
Old 10-30-2017, 02:36 AM   #17
5150777
5150777's Avatar
Drives: 2019 Satin Steel Metallic ZL1
Just installed my Pirelli scorpion 20's for winter. Had NO issues with the snow, and we get alot in Canada. Rims are from a 2015 Camaro SS, no problems with the Brembos. Had them powder coated last week, much nicer than the silver.
5150777 is offline   Reply With Quote
Old 10-31-2017, 01:02 PM   #18
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
Does anyone know of a website where you can enter a certain wheel size, bolt pattern, and offset and it will tell you what vehicles they will fit? I have been trying to sell some winter tires and wheels from my 2014 2LT, but haven't had any luck. Hoping I can find what other vehicles they will fit and maybe have better luck. Thanks.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25
2000 - 9/28
3000 - 9/30
3100 - 10/27
3300 - 10/28
3400 - 10/29 TPW 11/09
3800 - 11/10
4300 - 11/24
4B00 - 11/25
4200 - 12/5
5000 - 12/7
6000 - 12/11
i007spectre is offline   Reply With Quote
Old 11-06-2017, 05:41 PM   #19
GP86
GP86's Avatar
Drives: 2017 2SS
Enormous balancing weights
@Rudy@TireRack
Are there any options for thinner balancing weights? I am finding now that the front wheel weights on my 18" wheels are hitting something at full lock in either direction on my 2017 2SS. Any suggestions? I'm not opposed to having them re-balanced locally since I need my TPMS reset anyway, but I was hoping to get lucky and not have any fit issues. I can hear the impact of the weights when the car is moving and steering is full lock, and the pictures below show some sort of coating on the weight that is peeling back. This is on the inside set of weights on both front tires.
  • 2017 2SS with mag ride
  • Square on all 4 corners
  • 18x8 Anthracite Painted Sport Edition P5 wheels
  • 32mm offset according to TireRack.com
  • 245/50R18 Pirelli Winter Sottozero 3 Run Flat Run Flat
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
GP86 is offline   Reply With Quote
Old 11-07-2017, 02:13 PM   #20
sixstrings
sixstrings's Avatar
Drives: 2016 Mustang GT PP
@Rudy@TireRack
What would you recommend for a 1LE? Planning on purchasing one soon, but worried about winters in NJ.
sixstrings is offline   Reply With Quote
Old 11-07-2017, 09:44 PM   #21
z2f2ss
Drives: 2017 Camaro 2SS Hyper Metallic Blue
hi guys, does anyone know if these wheels will fit a 2ss non-brembo without rubbing or any problems? they are the e92 m3 wheels with Wheel bolt pattern is 5x120
Rear pair: 255/40/18 Michelin pilot alpin
Front pair: 235/40/18 Dunlop Winter sport 3D
wheels are a very different world for me and i just need to get a cheap but good wheel tire combo. i couldnt care less about the looks, its winter!
z2f2ss is offline   Reply With Quote
Old 11-07-2017, 09:45 PM   #22
z2f2ss
still have these wheels? do they come with tires? im in the KCMO area
Old 11-07-2017, 10:37 PM   #23
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Originally Posted by sixstrings View Post
@Rudy@TireRack
It's strange that the setups on tire rack use gigantic wheels and for the most part, do not down-size. It seems their "winter tire and wheel packages" leave a lot to be desired. There are some other good threads on this. One guy is running 19" 8.5s with 15mm offset. I'm jumping on his bandwagon, I'll put 245 or 255s on it. I made a spreadsheet that showed me what tire and rim combos would fit, from there you choose what size tires and rims you want to run, which depends largely on what's available. While there have been a few that have gone to 285 winter tires, that's just ridiculous in my book, on the other hand, there are lots of choices in the 245-255 range, so if you want max availability, that'll do you nice, it's also a decent intermediate size. I run 245 winter tires on my bmw and they handle amazing in the snow. Contrary to popular thought, you don't really need or want overly skinny tires. If you are really pushing through that much snow, you'll be a snow-plow with the air-damn and front bumper. That logic only really applies when you are having to drive through significant deep snow, vs. when it snows and packs down.
JamesNoBrakes is offline   Reply With Quote
Old 11-08-2017, 07:16 AM   #24
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
I'm running a 19x8.5 +20 square setup with 245/40/19 Pirelli Sottozero 3's. The fronts are a little tucked in, but the backs fit pretty well. No clearance issues whatsoever.
RXtacy is offline   Reply With Quote
