04-15-2021, 05:57 PM | #15 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Even if I could get E85 at the pump, I wouldn't use it. Z OH 6 is right, you can never know what the actual E content of the pump fuel is. If you test one batch, it's only good until they get another dump. It seems to me, my way is simple. I stop at the gas station when I'm at a quarter tank or less. I put in seven gallons of 92 and go home and dump in 7 gallons of E98 and call it good. |
04-15-2021, 06:03 PM | #16 | |
'20 ZL1 1LE A10,
04-15-2021, 08:29 PM | #17 |
Drives: Gen V Viper GTS Join Date: Jan 2018
Hard to believe a ported snout on a stock car will yield 30-40rwhp SAE... .
04-15-2021, 11:21 PM | #18 |
Drives: 2018 Red ZL1 Join Date: Mar 2018
IMO Yes it's worth the blower port. Had mine done by Jokerz. Had the Full Tilt port. You can see my mods in signature. Did the port on second round of mods after LTs, pulley, intake. Second set of mods were port, 103 Nick Williams, big gulp, retune and weapon x boost chiller so I wouldn't lose hp to heat soak. Now at a little over 700 whp. It also whines almost as loud as a hellkitty now!
Mods: RotoFab Big Gulp, 2" Kooks, Metco 9.1" pulley, Green belt, 103 NW TB, Tune, WeapX Boost Chiller, ADM Coolant reservoir, Jokerz Full Tilt SC Port, Elite E2X Can, Corsa Sport Catback, LED markers, 1LE Tail lights, HO reverse LED's, Red SC Lid, Forgestar 17x11/MickeyT Street R's for Drags
04-16-2021, 03:23 AM | #19 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Its around 30WHp STD on a stock car, can be as much as 40whp STD on a modified car.
04-16-2021, 07:14 AM | #20 | |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I will find that video and link it here.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
04-16-2021, 07:22 AM | #21 | |
I found one of the videos...
And this is before he did a pulley swap...
04-16-2021, 07:48 AM | #22 |
There are several ways to get to 700whp, but the reality is that's about the limit no matter how you get there before you need additional fueling mods or meth.
04-16-2021, 08:11 AM | #23 |
To expand on your post - a totally stock pump gas fuel system is about 650-675RWHP (on a dynojet). With a camshaft and 38% fuel lobe it can be pushed to 750-770RWHP before it runs out of low side. With a DSX low side you can get in the 820-830RWHP range. After that you will need high side pump and injectors.
'20 ZL1 1LE A10,
04-16-2021, 08:38 AM | #24 | |
04-16-2021, 08:45 AM | #25 |
Petro-sexual
Living in CA, I look at these kinds of mods' through that lens.
To me, this seems like a worth while mod'. Personally - most what I do is try to keep an OEM appearance. This falls into that 100%, and you're doing nothing to diminish anything, while getting all benefits. You'll be limited to power gains, but if you already know you what you're goals are, maybe this mod' falls within that set-up. While it was 4-times more money, I knew I wanted more power than porting would allow. I also knew I wanted more efficiency and better temperatures. Even though I'm still waiting on certification (it's still in process - I just checked), there's no reason to think it won't happen. So - even though I paid a lot more, I'm making the power I wanted, I'm going to be totally emissions-friendly in CA, and I'm going to have better efficiency. Minus a couple small things, I'll have the power I wanted with no fuss (well - a tiny bit that will take minutes to correct). I've had too many issues with law enforcement, so mod'ing the way I have, while having less dollar-per-horsepower than FBO with a ported blower, I can rest knowing I can drive any time I want and not have a problem with enforcement. Each situation is different as much as the individual. I think if you are honest with yourself about what your goals are (if you haven' already done this), that will make navigating through your options a little easier. That has helped me. I see a lot of Californians go balls-out on their builds, and don't understand how they plan on using the cars (I'm sure when smog time comes, they might know a guy they can go to or something), but it seems like enforcement is looking at mods' more and more. Maybe they only keep their cars for a few years and then dump them. Me - this car is my keeper and dream car, so it costs a little more to do it the way I am. I don't think many people plan to keep their cars more than a few years.
04-16-2021, 08:48 AM | #26 |
Petro-sexual
I haven't dyno'd my car, but it's almost exactly the same as another Member, and he's a little more than 700 to the tires. I can definitely start seeing my low-side start to fall a little; my high side doesn't change yet. So that seems to line-up reasonably with your comment. I'm right in the mid-5s for IPW, so I'm close to the edge there, too. I might have to look at either a booster or the DSX.
04-16-2021, 09:57 AM | #27 | |
Drives: 2019 ZL1 Join Date: Mar 2019
700rwhp SAE corrected is about your Max as your injector pulse width gets to unsafe levels.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
04-16-2021, 09:59 AM | #28 |
Can we stick with SAE correction please
