04-17-2024, 02:54 AM | #43 |
Drives: 2011 Chevrolet Camaro 2SS Join Date: Aug 2020
It arrives tomorrow. I'll be snapping some pics out of the box. Hoping it will be identical to the true mpd1
04-17-2024, 09:58 AM | #44 |
Very cool sir!! If it is done as they used to be by Eric, the underside should be a show quality finish, and you will notice it is a two piece hood, molded together, underside, and outside section. Good luck, hope it's the real deal. Should be if they got the original molds..
04-17-2024, 09:48 PM | #45 |
So I got the hood. I was under the impression that the underside would be like the one in the earlier post with the provision for the cold air intake. Here it is. I dont know a damn thing about bodywork but its going to need to be cut around the edge of the hood that way it wont rub. Here are the pictures. How do I upload pictures on here??
04-17-2024, 09:51 PM | #46 |
Here are the pictures. The hood comes in white, so im going to see if a shop can throw a satin or matte black wrap on there. I might also ask around to see if its possible to trim the edge around to the hood to have a proper gap like OEM.
04-17-2024, 10:00 PM | #47 |
On the ride home, theres this spot with this mural outside so I had to snap a pic real quick.
04-18-2024, 10:54 AM | #48 |
Wow, the hood looks good, except for the gap issue and the fact that there is NO opening for the CAI and opening underneath the rear cowl for the air to come in. That's a bummer. Mine just bolted right on with NO gap issues at all. I guess that is one of the many "details" that Eric paid attention to when he made his, that's why he had such a quality product people wanted..Looking at the hood underneath, looks to be the "plain" COPO hood, not the functional cowl hood I have. Eric sold both when he made them, along with rear spoilers, diffusers and splitters.. Anyway, love the cowl hoods!!
04-18-2024, 03:00 PM | #49 | |
Yea... I emailed them regarding the correct underside. I have yet to receive a reply back. I could have sworn there are 3 versions of this hood. The Functional one that you have. The copo showroom one and one more. I think the one that I have is the one that the green Camaro on this post has.
04-18-2024, 03:07 PM | #50 |
But the quality of the finish is amazing. I will admit that. A little bit of trimming on the edge won't hurt at all. I'll see if I can make it work for now.
04-18-2024, 07:09 PM | #51 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
It looks pretty good, and this trimming is no problem, most fiberglass hoods needs fit and finish before paint anyways!
04-18-2024, 08:16 PM | #52 |
Could anyone confirm for me what the actual hood gap size is on the edge of our hood, all the way around between fenders and front bumper?? I want to use that as reference. Im going around asking for quotes at the moment.
04-22-2024, 11:30 AM | #53 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Also, it looked like a gloss painted white. Is it actually painted? Or is it just a gelcoat? If its painted, I might just have one more reason to pull the trigger on this hood myself.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
04-22-2024, 12:34 PM | #54 |
Hey there, I replied to your PM, mine is 1/4 inch all the way around, with about 1/8th inch between the hood and front bumper cover.
04-22-2024, 12:38 PM | #55 | |
04-22-2024, 12:40 PM | #56 | |
