06-21-2017, 01:28 AM | #1 |
1LE suspension package or BMR suspension
trying to decide if I should get the 1LE suspension upgrade or get BMR Suspension. With the 1LE kit ill still need to add some BMR stuff but the 1LE kit has the program for the MRC.
06-21-2017, 02:59 AM | #2 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Definitely going to be getting the BMR stuff that will help me launch more straight.
As far as the 1LE or BMR versions of the sway bars and stuff, I don't know. Still kind of waiting to see if GM gets it's act fully together with the flash for the magnetic ride controller.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
06-21-2017, 09:22 AM | #3 | |
With that said, there may be a point of diminishing returns that BMR can hit with its products. Specifically the rear suspension links and arms to give further traction. The bars may work great too for adjustability but I will say that the best springs right now in terms of performance are the 1LE factory set due to spring rates and being linear. Until the aftermarket comes out with a higher rate spring for the 1LE setup, it's a tough call.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor Last edited by F1FTY; 06-21-2017 at 09:34 AM. |
06-21-2017, 09:34 AM | #4 | |
Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
I'm going with the L1E setup just as an enhancement and possible light track use. But I do like the BMR stuff. I used some of their products when they first started in business and even then it was quality stuff. |
06-21-2017, 10:23 AM | #5 |
Drives: 2016 Camaro 2SS Join Date: Sep 2009
Thanks for the consideration of our product.
We have designed out parts to deliver the best performance all around while still delivering the best ride quality, comfort and longevity. Our springs are US made to our specifications and guaranteed for life against sag or fatigue. Our sway bars are available in 2 different forms; Adjustable and non adjustable. Our non adjustable bars are for the every day driver looking to improve handling without getting too in depth into the suspension. Our Adjustable bars allow you to add wheel rate to either the front or back in the relation that you like to meet your driving style and preference. All of our parts are developed, tested, and built right here in the US. We put our parts to the test before we even offer them to the public and make sure that not only they are built to last, but also perform the added function they are designed to do. If you have questions on components for your build, feel free to call me and I can put together a custom package for you tailored to your needs and budget. This will ensure you get the right parts at the best price possible |
06-21-2017, 10:39 AM | #6 | |
Drives: Summit White 2016 2SS Join Date: Jan 2015
As well, I have and love my BMR parts, see the list in my sig. The car is a beast in the turns, and on the strip!
2015 1LE sold
2016 2SS sold |
06-21-2017, 03:25 PM | #7 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I had the same question (1LE vs BMR) and I ended up going with the BMR for a few reasons
1) I wanted the adjustability of the BMR sway bars since I do track my car quite often. I have not noticed any MRC issues with the BMR springs and it doesn't seem "bouncy" at all to me. There is also now an aftermarket MRC controller that I may eventually add 2) I did want it lowered for CG and the BMR springs were the only linear rate aftermarket springs I saw out there. So overall I don't see any downside to going aftermarket if you plan on tracking your car (except warranty) since you will have much more adjustability (sway bars and MRC calibrator) than you would with the 1LE suspension kit. |
06-26-2017, 10:28 AM | #8 |
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS Join Date: Aug 2016
Another vote for BMR. I did sway-bar kit, end links trailing arms, springs and control arms. Kinda of the best of all words for track and 1/4 mile.
2016 Hyper Blue A8 2SS
GM Bodykit: Black MRR 017 wheels: Black OEM Blackout tail-lamps OEM SEMA Grille 35% window tint Black glow-tie BMR Suspension (Pretty much everything) ACS rear-deck spoiler Rotofab CAI Lolly-pop red rotors by Madison Powder Coating |
06-27-2017, 04:03 AM | #9 |
im not planning on lowering. our roads are bad and drive ways into lots already scrape the front air dam and im putting on a spitter.
i want to know if there is a noticeable difference with the MRC program. right now im thinking of going with the 1LE kit and BMR delrin cradle bushings, upper lower trailing arms, upper control arms and toe rods.
06-27-2017, 09:18 AM | #10 | |
06-27-2017, 10:00 AM | #11 | |
I pulled the trigger on ordering the 1LE kit even though I have a '16. I'm running an E-force supercharger which adds about 100 lbs to the front. The heaver spring rate in the front will be welcomed. Worst case is even if the BCM programing doesn't come through, several folks here have convinced me the performance and ride quality won't be a problem. |
06-28-2017, 08:51 AM | #12 | |
06-28-2017, 09:21 AM | #13 |
Drives: 1973 z28 Rs, 2018 SS 1LE Join Date: Jun 2017
Have you guys seen detroit speed has a prototype coilover kit, I'll eventually go with them. I want the handling just right on this car even though its already a 1le...
06-28-2017, 10:02 AM | #14 | |
I'll give the FE4 sway bars a try, but if they don't cut it, it's not that big of a deal to swap them out for the BMR items. |
