Old 11-04-2017, 12:30 AM   #1
11bravoss
Drives: 2018 ZL1
Am I ok wsith bias ply
Hey guys and gals, I need some help with a tire available to me.
Car in concern is a 2018 M6 zl1. Tires in question is a set of mickeys in 28x11.5/17 bias ply. As of now I do not have front runners and have heard that without them a bias ply will casuse bad wheel hop. Do you think I will be fine? By the time I get them on the car I expect to be around 700 to the wheels. If I decide to stop being cheap I might invest in the 20in front runners.
11bravoss is offline   Reply With Quote
Old 11-04-2017, 07:54 AM   #2
motorhead
So you are saying that you will be running bias ply on back with Radial front?
If so, that is a very bad Idea. Especially if its going to a sreet driven car too.
Old 11-04-2017, 08:23 AM   #3
11bravoss
Drives: 2018 ZL1
Yes unless I find more options for front runners in a 20. Btw the bias would be for the track only
Old 11-04-2017, 10:52 AM   #4
motorhead
Ive seen fellows try that at the track, usually ending up with a very squirrely car.
Bias on front and radials on the rear seem to work okay even though mixing at all isnt recommended.
Old 11-04-2017, 03:35 PM   #5
TheRedhead
TheRedhead's Avatar
Drives: 2018 Red Hot ZL1 1LE
The rear bias tends to flex. Radial fronts do not.
So, your back end will sway, etc.
It's not a smart idea...
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built!
TheRedhead is offline   Reply With Quote
Old 11-04-2017, 08:06 PM   #6
trz174
trz174's Avatar
Drives: Used to Drive Blue Camaros
My experience with bias ply on the rear and radials on the front is the same. It starts to get squirrelly at a bit less than half track and gets worse till you back off. It’s a sway from side to side with the steering wheel in the dead straight position. Trying to correct makes it worse. Same rear setup with bias on the front is dead straight and stable. Not fun and certainly not safe if another factor requires some wheel movement. Lower tire pressure makes it worse and it happens more quickly.
Bias on front with DRs on the rear have not been a problem for me. Always dead straight with no drama.
trz174 is offline   Reply With Quote
Old 11-04-2017, 08:27 PM   #7
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
This is how I ran my car for the last 2 years. Hoosiers in back and stock up front. It was not unmanageable, but I can tell you on my last pass I missed 4th and the car got way out of the groove. I ended up about 12” off the wall while aborting the run. It was enough of a shock for the owner to ask me what happened, wondering if the track had an issue.
Can it be done without consequences, yes.
Is it recommended, definitely not.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 11-05-2017, 03:39 AM   #8
11bravoss
Drives: 2018 ZL1
Thank you for the advice guys
Old 11-08-2017, 09:17 AM   #9
11bravoss
Drives: 2018 ZL1
If I end up getting skinny for the front do I also need to run bias ply on those or can I get radial for those since they are skinnys?
Old 11-08-2017, 08:08 PM   #10
motorhead
You need bias ply up front regardless with the rears you listed that you will be using.
Old 11-08-2017, 10:40 PM   #11
11bravoss
Drives: 2018 ZL1
Ok thank you
