03-29-2019, 04:34 AM | #15 | |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
My ZL1 pump drops fuel pressure and maxes out quick on DC with E85. That's before the DSX pump kicks on at 9psi boost, too. Wonder how I could get it to kick on sooner like yours at 4psi?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
03-29-2019, 06:45 AM | #16 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Mine actually kicks on pretty instantly (2psi). Usually when I floor it, I'm instantly at 6 pounds of boost to start, so its on immediately. That will fix your fuel pressure issue.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-29-2019, 10:40 AM | #17 |
Looking at that DW400. It does look like the best returnless system. Could be used with the DSX pump also.
03-29-2019, 11:01 AM | #18 |
AGP has a twin pump setup ,E85 compatible, that is priced really reasonable. It's good for up to 1200whp.
On a separate note, for informational purposes, with just the ZL1 pump, ADM FPCM, the LS9 cam, stock diameter balancer, my car made 600rwhp with the 4" pulley on the Whipple, and 630 with a 3.75". -Scott |
03-31-2019, 10:29 AM | #19 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
Shoot me an email (dave@dsxtuning.com). We will get you squared away.
Tags |
advice, fuel injectors, fuel pump, injectors, pump |
