03-21-2018, 03:37 PM | #1 |
Drives: 2018 2ss 1le Join Date: Jan 2018
m6 synthetic..
has any one changed the fluid in their m6...
if so what was the out come, is there a synthetic out there that would make any differences |
03-21-2018, 03:40 PM | #2 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
You might try a search, but I believe several have switched to Royal Purple Synchromax with positive results.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
03-21-2018, 05:00 PM | #3 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
I switched to the Mobil 1 Dexron III ATF. I also haven’t done much driving since....it’s been crappy weather. But it shifted nice the first time I went for a quick spin with cold fluid.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
03-21-2018, 05:16 PM | #4 |
Drives: SS Join Date: Jan 2017
I used Redline D4 and the shifts are a lot smoother. Cold operation seems a little better too.
03-21-2018, 06:37 PM | #5 |
Drives: 2019 CTS-V Join Date: Feb 2016
If you search transmission fluid on Camaro6 you will find everything you need. Im switching to Royal Purple.
03-21-2018, 07:22 PM | #6 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Over winter I switched to redline D4. I've done one test drive in 42° weather and it is night and day difference. The factory fluid forced me to put the car away early this past fall because it didn't like to go into 2nd at all in mid/late October around the same temps. All gears felt notchy as well. Last Saturday the car drove awesome, like it was brand new.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
03-21-2018, 09:05 PM | #7 |
I'm figuring ill wait till the 1500 mark...
let the tranny break in and then do diff, tranny and engine bought mobil 1 75/90 for the diff i was hoping to get my hand on mobil 1 esp 0-40 fro the motor but looks like only available in Europe I'm leaning toward the royal purple for the tranny.. |
03-21-2018, 10:19 PM | #8 |
Drives: Sold! Join Date: Nov 2017
I went with Royal Purple - much better shifting, especially cold.
Whether you’re in the RP or Redline or whatever camp...you should see a pretty noticeable improvement over the factory fluid. |
03-21-2018, 11:25 PM | #9 |
Drives: 2017 Summit White ZL1, M6 Join Date: Jan 2017
Switched to RP. in talking to Cal Webster; later he did a write up on here somewhere, as well. Definitely felt like an improvement over stock fluid. Shifting was smoother imo.
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396 |
03-22-2018, 07:07 AM | #10 |
I still have factory fluid in my car, but have noticed the transmission smoothing out significantly just recently after ~ 3200 miles.
03-22-2018, 10:16 AM | #11 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I just switched to RP syncromax this past weekend. I haven't driven it yet. but from what others are saying this is the go to oil for M6 trannys.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
03-30-2018, 03:41 PM | #12 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I run rp synchro as well, had it replaced at 1500 miles, I'm at 5500 now. I was just thinking about it yesterday, its shifts so smooth, I feel I could put it into gear with one finger if I really had to, hah. I have read th way it smooths out with the stock fluid as well eventually, but I didn't want to wait.
03-30-2018, 05:05 PM | #13 |
Drives: 2017 Chevrolet Camaro SS 50th Join Date: Oct 2016
That's also what I'm hearing for the 6 speed manual is the royal purple stuff, haven't changed mine yet but that's what i'm going with. As far as the differential I went with the AC Delco 75W90 with the limited slip friction modifier already in it. No concerns with it yet anyway. My differential was always quiet I just changed it out at 1500 miles all good.
03-30-2018, 08:05 PM | #14 |
Did anyone confirm the rp will not deteriorate the blocker rings?
