11-05-2018, 09:53 PM | #1 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Wastegate on Centrifugal
Curious if anyone has built / tested running a centrifugal with a constant blead wastegate?
I know a couple of guys with this kind of setup on Coyote mustangs and they run incredible vs PD and a Centri with just a blowoff valve (much stronger in the mid range) Anyone doing this kind of thing on the LT1? |
11-05-2018, 10:01 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
Pretty much can take all the low and mid range boost that the blower can put out even with very small pulley sizes, so there is no need to bleed boost off.
11-06-2018, 05:37 PM | #3 |
The whole concept works by over-spinning the SC then setting the WG at 8 or 10psi so the intake pressure is at higher pressure at lower RPM, vs at peak boost for the last little bit of the power-band.
Like I said, I drove a 2012 Coyote Mustang that had this kind of setup and it was incredibly strong vs the same setup with a BOV (both cars had Paxton SC, same intercoolers, tuned for 91, etc...) and the WG car had to be making another 100ft lbs at 4500rpm. This is a pretty popular & proven setup, just curious if there is anyone trying it on the LT1? |
11-06-2018, 06:05 PM | #4 |
understood, and the engine can take all the boost the supercharger can supply even with small / smallest pullies, so there is no reason to bleed boost. On the P1X they are running close to max RPM of the unit at red line of the engine.
11-07-2018, 07:51 AM | #5 |
Drives: All GM Performance Join Date: Jul 2011
We have done it, I don't like it lol. Give me the boost all the time. I'll change power in the tune.
11-07-2018, 09:48 AM | #6 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I have a D1SC on my SS 1LE and even with the Tial 2" BOV I can still tell that the supercharger is boosting power in the lower RPM levels. I can already break the tires loose at half throttle from 2k RPM's, I cant imagine wanting even more low RPM HP or TQ on a RWD setup. if the Camaro was AWD it would be a whole nother world.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
11-10-2018, 07:25 PM | #7 |
Drives: 2016 2SS Join Date: Oct 2016
I was toying with this idea in my head for a while. The ability to hookup a boost controller to the wastegate would be awesome. You could run different power level maps or boost by gear if you have the correct hardware. I'm still interested in it! What was the setup on your mustang like?
2016 Camaro SS- , D1SC, 4.38" pulley, LT4 HPFP
11-11-2018, 04:10 PM | #8 | |
I've noted that the P1X guys seem to be taking all the boost the 3.75 pulley is bringing them. So it we are really talking a D1X on pump fuel with 3.75 pulley as the D1X has a lower RPM limit for the wheel and the wheel puts out way more boost at any RPM.
11-11-2018, 05:01 PM | #9 |
OK so here is the link to max blower speeds for Procharger:https://www.procharger.com/automotiv...-superchargers
Given my 6800 RPM fuel cut, 4.10 internal ratio and 62000 RPM max blower, I can do some Math: um for sure the max shaft speed for the blower is: 15,122 RPM. The smallest pulley that I've seen for the bower is 3.75" which has a circumference of: 11.781" bust the crank pulley from procharger diameter: 7.65 and get a circumference of 24.033" so at 6800 rpm the belt travels 6800 x24.033" = 163,424" per minute this goes to 13,872 RPM at the supercharger shaft or about 56,874 rpm at the wheel. Heck you can even go to a smaller wheel,especially on the P1X 6800 RPM, 163,424" of belt speed will yield: 56,874 blower RPM for the 3.75" pulley 53,319 blower RPM for the 4.0" pulley and the pulley that I run the 4.5" 47,396 blower RPM for the 4.5" pulley, heck it is hardly spinning.... LOL going the other crazy way: 60,973 RPM for the 3.5 pulley... near max bursting RPM. The D1X at this point (never saw a Procharger wheel map), I have worked with billet wheels and Powerdyne, the unit should be flowing 1000 HP worth of air. So say the ride is rated at 800 engine HP, that would mean your one or two BOV would be bleeding 200 HP worth of boost... shiznet is gonna be loud.. Probably if the make it, at 3.65 would give a little more headroom. for the P1X this should be fine. Others please check my math. 3.25 pulley 65,624 RPM which is boom for the blower
11-12-2018, 08:36 AM | #10 | |
