01-14-2021, 11:17 PM | #1 |
Drives: 2015 Join Date: Jan 2016
A/C Actuator/Door
Took 2015 SSRS to small shop.
Mechanic was not sure if actuator or door. It would have some cold air when engine cold but later becomes not cold air. Mechanic disconnected heater hose to engine block. Now no warm air but have nice cold air for a little while then not as cold air other times, as if actuator or door is faulty. Question: if I go to Chevy dealership how well can they fit it, so that it blows nice cold air like a fairly new car? Also, does the A/C last longer if never turned off, and never use heater? For me seems too cold winter time in Hawaii at 5am. Aloha, Eric |
01-15-2021, 08:21 AM | #2 |
The actuator door fix at dealer will involve major surgery on the car, including dash removal and likely windshield removal. Expect a very large bill. There are various shortcuts that can be taken throughout this forum.
A popular theory on here is that the less you cycle the ac/heat the longer it will last. Also some recommend to not turn the AC to final coldest position. I just checked on temperature this week for Honolulu this week and a low of 64 and a high of 80. Those are the exact ranges I turn off the heater and ac. |
01-15-2021, 09:09 AM | #3 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
And they replace it with the same wonderfully under engineered plastic door.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
01-15-2021, 09:35 AM | #4 | |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
01-15-2021, 04:43 PM | #5 |
Drives: 2014 2SS/RS Join Date: Dec 2014
For about $30 and an hour worth of time you can make a tiny access door that will allow simple replacement of the blend door.
A Bonus is the access panel opening made is neatly in an area nobody can see. This vid shows the technique. https://youtu.be/K0jajaoc-ro
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
01-15-2021, 08:57 PM | #6 | |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
01-16-2021, 07:29 AM | #7 |
For one thing it's not $3500 it's more like $1800. I don't know how much it is in Hawaii but that's what the dealer here in Texas charged me. And I'm not sure but I think it takes a little longer than a hour unless someone on here can confirm that.
01-16-2021, 08:30 AM | #8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
This thing is my nightmare. It’s like a tranny R&R, cost wise, for that BS plastic door. Is there any truth to the NOT turning the temp dial all the way to the cold blue dot thing?
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
01-16-2021, 09:03 AM | #9 |
My understanding is every time you turn the key on it cycles the door. I set mine two notches short of full cold and unplugged it. I could plug it back in once just to change settings for the season but it's not a DD.
01-16-2021, 09:07 AM | #10 |
It don’t come easy.
That’s where I keep mine. Seems to be doing the job.
01-16-2021, 11:22 AM | #11 |
Drives: Chevy Camaro hwse 2018 GMC Sierra 1 Join Date: Jun 2019
How do you unplug it?
01-16-2021, 12:54 PM | #12 | |
Then I blew my L99 and let the car sit for 4 months. The AC worked great before I blew the engine. But I guess letting it sit for that long with it turned to max cold caused issues with the blend door, because after I swapped in the new engine I had no AC. The door somehow broke while the freaking car was just sitting there. I wound up doing the cheap fix by cutting a door into the airbox. The main benefit of this is that if it happens again it will be a 1 hour repair since the door is already there now. I am considering buying up a few of the blend doors though, as GM has a nasty habit of discontinuing much needed parts.
01-16-2021, 04:54 PM | #13 | |
Yeah I hated to pay the dealer that much money to do it but was afraid I was going to screw something up. I'll give it to you for having the guts to do it. I guess if you feel comfortable doing it go for it. Like I said I partly did it because I needed a new windshield anyway.
01-21-2021, 09:58 AM | #14 | |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
There's a video in the Blend Door thread that seems to show the validity of this idea. I live in Southern Indiana where the summers aren't scorching hot. As such, I never touch the AC unless my wife is in the car (which isn't often because she hates how low it sits and how I drive), but I never put it anywhere near the Max AC setting regardless. It's open windows for me in the summer. |
