10-12-2020, 03:44 PM | #1 |
It don’t come easy.
Heat sleeves
Thinking about doing LT’s in the spring and thought I’d pick up as set of those heat sleeves for the plugs wires. Any recommendations out there?
10-13-2020, 02:28 PM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I can tell you that the DEI are a bit better than the Heatshield Products.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
10-13-2020, 02:47 PM | #3 |
I used DEI header wrap instead of coatings. Keeps my underhood temps very low.
https://youtu.be/mkhnI-1j_yY https://youtu.be/WnJFeZL-psc https://youtu.be/Bu620erOJTI
10-13-2020, 04:46 PM | #4 |
It don’t come easy.
I figured as much with the quality and price, from what I can see. Definitely don’t care much for what I see on Amazon.
10-14-2020, 07:18 AM | #5 |
I use pcm of nc wires and heat socks. Very good quality and I've had zero issues.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
10-14-2020, 08:32 AM | #6 |
I used Spark Plug Protect Boot 1800 Degree Heat Shield Thermal Protection Insulator Sleeve Spark Plug Wire Boots 6 inch for Car Truck off Amazon and the LTs are coated also.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
