Old 04-29-2023, 10:34 AM   #1
1leny
Drives: 1le
Track set up size 18s
Hey all
I have fitment question
I just got delivered apex SM10 18X11 ET7 18X12 ET 41
Any issue running NT10 315 front 335 rear ?
Also think about try pzero
WHERE DO YOU GET piero scrubs?
Apex website show no shave requird.
May I run 305 35 18 rear 335 30 18 rear bc I have a set from my buddy
There diameter is about 1inch different
Thanks in advance
1leny is offline   Reply With Quote
Old 04-29-2023, 10:58 AM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I run 325 square pirelli scrubs on 18x11, no issues with that. Not sure if 18x12 with 335 will rub in the back, but your fronts should be no issue(after the strut grind). I got my scrubs from a friend but I think the other option is to go to usedracing tires.com
Christian1LE is offline   Reply With Quote
Old 04-29-2023, 11:54 AM   #3
1leny
Drives: 1le
Thanks for your info , so strut grind is must ? Hmm
305 35 18 335 30 18 should be okay?
My guys not in stock rears
I'll give him a call
Thanks 👍
Old 04-29-2023, 01:02 PM   #4
Christian1LE
Thanks ��
Oh you might not need strut grind with the staggered setup, just the square set. If Apex says you don't need it you should be good(although I don't think apex recommends any 325 sizes up front). I would take a peek under and see if the tire is close to rubbing on the strut. That would be a massive failure on track if the tire rubs during lateral loads. I'm running the 26mm spacers up front for my setup. I had to grind my struts a lot.
Old 04-29-2023, 03:38 PM   #5
1leny
Drives: 1le
Ok ZLE may not require grind
I probaly stay 305 either 315 front
Apex recommend 315- 30 335 -30-18
Picking up used set of NT01s 305 35 335 30 18 from my buddy. Hopefully work out well
Thanks for advice ��
Old 04-29-2023, 04:31 PM   #6
Christian1LE
Do 18's fit on the ZLE calipers?
Old 04-30-2023, 08:53 AM   #7
1leny
Drives: 1le
Yes I have seen 18s SV , bcforge,etc
