06-27-2018, 11:07 PM | #1 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
1st Ever Track Day
I'm looking to run either Charlotte's ROVAL and/or Dominion Raceway in Northern Virginia next month and after viewing all the threads. I like to make this one to encompass everything possible.
1) I'm at 2300 miles of this writing so I am about to get my oil changed. If I decide to put 5w-40 instead of the usual 5w-30 in my 18 SS 1LE is the 5w-40 ok for daily driving since that's what I do most with the car. 2) if I go with the -2.0 front 1.5 rear camber settings is leaving those adjustments dialed in ok for street use without putting extra wear on my Summer Only Goodyear's 3) With the car still be fairly new, it sounds like the stock brakes pads should hold up on at least one track run unless I'm diving bombing corners like hell. What are the best pads for street/track use? The stock pad brake dust I read about is worse than I thought. I'm not heavy on the brakes at all and the dust is annoying, makes the wheels especially the fronts look rusted even from a distance after a few days. 4) Even in my old 96 v6 Camaro with a 5 speed I never did rev match downshifting so I use active rev match a lot and found downshifting between 1500 and 1000 RPMs doesn't buck the car/bog down the motor but i don't want to run Active Rev Match and Traction Control since it seems like most others don't to get the best feel for the track and the car overall. From the videos I've seen, is it best to just shift the gear and blip the throttle during the throw or hold neutral for a sec and blip the throttle while still in neutral then go into the desired geared? 5) For the long term for year round driving, what would be some good tires to invest in for both street and track use? Mind you as of right now I probably will only run about 5-10 track days a year at most. 6) I'm definitely changing the brake fluid to either DOT 4 or SPF 600, is there a better daily driving preference between the two? Whatever I put in the brake lines I like to keep there after the first track day if possible. Thanks for any/all input. I'm trying to be cautious the first time out and not wreck a car that took me 25 years to finally buy something like this on my own.
2018 Camaro 1SS 1LE
06-28-2018, 06:01 AM | #2 |
brake fluid definitely swap to DOT 4 & stock pads are fine. Alignment isn't absolutely necessary. Adjust air pressure at the track to 29 psi cold for your first runs. Have fun and pay attention to traffic.
06-28-2018, 08:00 AM | #3 | ||||||
Drives: 2017 1SS 1LE Join Date: Jun 2016
TC - engine power limiter to avoid spinning the wheels from throttle application ESC - brake applies to specific corners to help maintain stability and avoid unintended yaw (spinning out) Wet- TC and ESC active, very sensitive and intrusive. Dry- TC and ESC active, less intrusive than wet but still noticeable Sport 1- TC and ESC active, less intrusive than dry Sport 2- TC active, ESC off, TC is less intrusive than Sport 1 Race - TC active, ESC off, TC is at least intrusive level and is not as noticable. At this level, you can still keep the throttle planted and spin out if you try to when exiting a corner, but it takes a lot and gives you more time to react/correct your inputs than if you have all systems off. All systems off - TC/ESC off, but ABS stays on. You can't disable ABS through the vehicle options, but I personally don't see any need to because it isn't very intrusive to track driving. Quote:
Also, do you have snow at all in central VA? Or temps regularly below 40°F? If you do, I'd suggest getting a second set of wheels to use a winter or aggressive-tread all season tire for the winter season. No decent summer tire is going to perform well in ~40°F or below conditions, and some (including the OE Goodyear tires) are prone to cracking or being otherwise damaged in temperatures that cold. Quote:
Another couple of things to note: -As mentioned above, lower your tire pressures to 28-29 psi cold before going on the track. As soon as you get in from your first session, check your tire pressures again. You want to be at 35-37 psi when they're hot. Take a look through the high performance supplement that came with the car as well as the high performance driving section of the owner's manual if you haven't already, has a lot of good information in it. -Don't forget about changing your diff fluid! You'll want your diff fluid changed once before your first track day, and again after your first track day (and don't push the car to its limits on the first day, either). Reason for this is that the eLSD is only partially broken in during street driving so you flush it to get those contaminants out, but then on the track you get stronger engagements than the street that will further break-in the diff, so you'll want to flush again after that to get those contaminants out. -Keep a record of your on-track driving hours. For these cars, the trans fluid should be replaced every 10-15 hrs of track use, and the diff fluid should be replaced every 24 hrs of track use (starting after you do the 2nd break-in diff fluid change). -If you haven't already, I'd suggest looking into a catch can as well. This isn't required by any means, but I notice that it filters out a lot of oil and crap from the PCV that would otherwise be dumped into the intake manifold. -If you have PDR, save the .mp4 files from each session! You can open them in the Cosworth Toolbox software and get a lot of useful data, and you can even potentially compare your lap head-to-head with other drivers that have PDR and use it to improve your skills behind the wheel. Good luck out there and have fun! These cars are great fun to run at the track.
2017 SS 1LE.
06-28-2018, 10:28 AM | #4 |
have fun be safe
