12-20-2020, 09:20 PM | #1 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
Finally got a flat :(
Are the low profile tires just like any other tire as far as being able to get the hole plugged if it's small enough and on just on the tread (not on the sidewall?)
12-20-2020, 10:14 PM | #2 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
As long as the puncture is not along either sidewall, you can still plug it. Good Luck!
Current: 2018 ZL1 ZLE
Memories: 2017 50th Anniversary Camaro Convertible (Sold) 2003 Dodge Viper (Sold) 2005 Lingenfelter Corvette (Sold) 2004 Mazda RX-8 (Sold) |
12-20-2020, 11:08 PM | #3 |
If you are still on the stock run flats you might be out of luck. If not, you should be able to patch it up and be able to roll out
My situation ended up get a nail wedged deep in the sidewall which forced me to get new tires and a sweet sweet burnout |
12-21-2020, 12:01 AM | #4 |
Yes it can be plugged but a patch is better in some cases. Good luck!
12-21-2020, 01:28 AM | #5 |
Appreciate the feedback. Yeah I ditched the run-flats years ago.
12-21-2020, 06:31 AM | #6 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I had my right rear plugged and patched about 18 months ago. It's held up fine.
12-21-2020, 06:56 AM | #7 |
I've plug/patched a run flat and it did fine.
