09-21-2019, 05:20 PM | #1 |
LED Turn Signals
I find it interesting that most of the exterior lights are LED's but the turn signals are not. Why is this and is it easy to change them to LED? I changed the reverse lights to LED already and I like that lighting much better. Also switched the side marker lights to Diode Dynamics which I really like. I'd like to make the blinkers be LED as well so that everything matches.
09-21-2019, 06:57 PM | #2 |
Well, the most likely reason is co$t savings.
The halogens are very easy to swap out for LED's, the only potential issue is low resistance that may cause hyperflash (the ECU will think one or both of the halogen bulbs are defective). I bought a pair from amazon that advertised built-in resistors and they indeed work perfectly and are much brighter than stock. This specific model seems to be unavailable, but there are others that look very similar (never tested any other myself, though). A word of warning, I'm sure these LED's with built-in resistors will overheat eventually, so the only place I'm willing to use them is for the turn signals that are active for a very short period. For this reason I used a proper resistor kit with the white reverse LED's.
09-21-2019, 07:29 PM | #3 | |
09-21-2019, 08:00 PM | #4 | |
Never gave me any problems and I've had both this thing and the turn signal LED's on the car for over a year now.
09-22-2019, 05:46 PM | #5 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
Reverse lights don't need to imitate the halogen current draw to make the ECU happy. They require a resistor (one shared for both) because the reverse switch that turns them on and off is garbage and leaks power that the LEDs can sometimes use and will look like they never turn off or flicker when they should be off. Halogen suffer the same issue but by their nature the power isn't enough to heat the filament.
You can use a high resistance resistor which can sink the current enough to not power the reverse LEDs when off but not enough current will go thru to make it hot when on. Bonus is the reverse LEDs will get full voltage too rather than in some installations with load resistors, getting slightly lower voltage. Edit:. The newer 2019 may be different from the info above, fyi Last edited by cellsafemode; 09-22-2019 at 07:42 PM. |
09-24-2019, 11:14 AM | #6 |
Drives: Chevy Camaro Join Date: Jul 2019
My turn signals are led in my 19 ss.
09-24-2019, 11:26 AM | #7 |
Drives: 2019 SS 2019 mustang GT Join Date: Apr 2017
Same here ! Switchback feature is pretty darn cool!
09-25-2019, 06:21 AM | #8 |
Drives: 2018 SS 1LE Join Date: Aug 2018
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I've had these in for months now with 0 issues, no hyperflash. |
09-25-2019, 09:13 AM | #9 | |
Also, how do you get to the drivers side turn signal. There’s a rubber cover in the way. Does it just pull back? Last edited by caSStro18; 09-25-2019 at 09:25 AM. Reason: Add more information |
09-25-2019, 12:14 PM | #10 | |
That rubber flap peels back and you can reach underneath to get the turn signal bulb socket out. If you have a relatively small hand, that is. My father sure couldn't do it, I was barely able to (but then it's reasy to remove the rubber cover if need be).
09-26-2019, 12:45 AM | #11 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
I think I'm gonna order a set of the VLEDS
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
09-26-2019, 08:42 PM | #12 | |
09-26-2019, 10:12 PM | #13 | |
01-28-2021, 04:03 PM | #14 | |
