02-02-2019, 03:19 PM | #1 |
Drives: 2018 1LT Camaro Join Date: Aug 2017
Remote start question
i used remote start while having breakfast when it was -8 the other day. but lot of good that did for the inside I had the heat turned on but i found out with remote start it don't heat the inside the fan only blows cold air WTH. After you start it from the inside then the heat comes on.
i put the heat on before i shut it off the night before. nothing else goes on either until you start it from the inside infotainment center is black, dash doesn't light up. is this normal?
02-02-2019, 11:16 PM | #2 |
Drives: Yellow 2018 SS Join Date: Jun 2011
I don't think that's normal. How long did you leave it idling? Could it be that maybe the engine didn't reach the proper temp to allow for full heat? I'd imagine at -8 it could be a bit before the heat works at all.
02-03-2019, 06:27 AM | #3 |
Drives: 2017 Camaro SS Join Date: Nov 2018
The heat and rear defroster should come on, as well as heated seats if you have them. That being said, it does take a while to warm up at -8!
Kevin
Luceo Non Uro |
02-03-2019, 10:59 AM | #4 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Check your settings...!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
02-03-2019, 01:11 PM | #5 |
it wont start to put out heat or turn on the fans until the coolant is hot enough to put out heat. the heater was on just it doesnt light up until you hit the start button. My Silverado need all of 10 min to get it going in single digits.
02-03-2019, 02:10 PM | #6 |
Drives: Chevy Blazer Join Date: Sep 2009
My window starts defogging in 5 minutes in the double digits.... These cars warm up quick, lol.
Sent from my SM-G965W using Tapatalk |
02-03-2019, 02:48 PM | #7 |
Emerald Coast Camaros
Drives: 2017 50th Camaro LT2/RS Join Date: May 2011
So that's different, I will see if I can turn on the heated seats from setting, currently mind do not come on with the remote start.
2017 LT2/RS, 50th addition. Airaid CAI, Solo Performance Axle back, sunroof, Smoked Led Markers
02-03-2019, 03:16 PM | #8 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
it's in the setting to set up what comes on when you remote start. Default on my car when purchased was everything was off. I have to set Heat/AC or Vent/Heated seat when remote started.
02-03-2019, 03:21 PM | #9 |
Thanks, great tip. The settings options are so key on these cars.
Kevin
Luceo Non Uro |
02-03-2019, 03:44 PM | #10 |
That maybe it I didn’t know there was a setting like that, I’ll have to check that out. Thanks
