07-07-2017, 03:41 PM | #1 |
Drives: 2015 camaro ss Join Date: May 2016
Tranny Temps over 230 with trans cooler?
I recently got a circle d 3200 converter on my car. To help with temps the shop that did my converter and trans cooler had to replace the 1st cooler cause the heat was so bad (temps over 232 degrees). They thought it was a bad cooler so they just installed a new one. I was logging it today on HP tuners and and after about 30 minutes of city driving the temp was a 215 and rising. I put it on the highway for about 15 minutes and still it did not cool. I have a 15 camaro with the smaller grill than the 10-13 camaros. Could that be the problem with the smaller grill on the 14-15? Any response is appreciated!
07-07-2017, 05:00 PM | #2 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
What cooler sounds like it's not very efficient.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
07-07-2017, 05:03 PM | #3 |
07-07-2017, 05:05 PM | #4 |
Drives: 2015 Yellow 2SS LT Z28 cai tune Join Date: Aug 2015
Same here. I have a adm and I dont think its efficient at all
07-07-2017, 05:56 PM | #5 |
07-07-2017, 06:08 PM | #6 |
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Got my Mishimoto installed with my 3200 Circle D.
115 here in Phoenix, city driving or highway NEVER above 190. Hth
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
07-07-2017, 06:19 PM | #7 |
Svt lol
I bought this little thing https://derale.com/products/fluid-co...il-hose-detail I never see above 195 when hot lapping in the 95 degree 95% humidity weather. I have a 3400 stall also.
07-07-2017, 07:13 PM | #8 |
Any chance both of yall have 10-13 body styles???
07-07-2017, 07:38 PM | #9 |
2015 225-235 normal driving and VERY slow to cool down on Hway
07-07-2017, 07:40 PM | #10 |
07-07-2017, 07:49 PM | #11 |
07-07-2017, 08:19 PM | #12 |
Drives: Camaro Join Date: Mar 2013
I seldom peak above 180.
07-07-2017, 08:53 PM | #13 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I got the ADM kit, and then upgraded to the biggest cooler B&M made. Temps really dropped, but, I don't have a stall, which is a heat magnet for sure...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
07-07-2017, 09:33 PM | #14 |
