Old 07-20-2017, 10:14 AM   #1
rfm4000
Drives: 2017 SS 1LE SIM
Rev Match problem
Does anyone else get weird revmatch problems, like going from 1 to 2, it blips the throttle really high and doesnt drop so you have to shift into 2nd really high like 3000rpms higher than it should be. This is going up too keep in mind, not down. Happened to me twice yesterday...
rfm4000 is offline   Reply With Quote
Old 07-20-2017, 10:31 AM   #2
JayhawkSS1LE
JayhawkSS1LE's Avatar
Drives: 2017 SS 1LE
I dont experience that on an upshift.
JayhawkSS1LE is offline   Reply With Quote
Old 07-20-2017, 10:46 AM   #3
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2017 ILE SS
Occaisionally. I've definitely noticed some flaws in the technology.... I wonder if Chevy knows and will issue a TSB for a reprogram or something.
Bad Anvil Garage is offline   Reply With Quote
Old 07-20-2017, 11:13 AM   #4
AZ_1LE
Drives: 2019 ZL1 1LE
Mine stopped working completely at my first track day and I chalked it up to me driving it too hard, but I dunno. It would only work if the revs were under a certain amount and I can't remember what that number was.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 07-20-2017, 11:21 AM   #5
davef
Drives: 2017 SS 1LE Garnet Red
Every now and then I notice that the car holds onto higher revs than it should leaving first gear. For instance in a parking lot situation and you go from first to second but mid shift you decide not to let out the clutch but you've already moved the shifter into second gear. It'll hold 3000 rpm for a while. It's rare though and does only happen when rev match is on.
davef is offline   Reply With Quote
Old 07-20-2017, 11:55 AM   #6
dotfiles
@SS_1LE
Drives: 2017 SS 1LE
It happens going from 1st to 2nd occasionally. I think it happens when you don't shift out of first soon enough after depressing the clutch. The car may think that you are going to stay in first instead of shift to 2nd.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S
dotfiles is offline   Reply With Quote
Old 07-20-2017, 01:28 PM   #7
Sleeks
Drives: None
This. Exactly.
Shift a little faster and it won't do it. If you are lazy/slow on your 1-2 it will think you are staying in first and bringing the revs up in case you let off the clutch in first.
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
Old 07-20-2017, 02:08 PM   #8
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
Slow shifting is a reason the computer gets confused. Going from 3rd gear to 4th too slowly makes the computer wonder if you are going down to 2nd and you get a blip.
The rev match is supposed to stop rev matching under 19 MPH but I have had the rev match run the RPMS up when I was rolling into a parking space in first at way less than 19 MPH.
Uncle Sam is offline   Reply With Quote
Old 07-21-2017, 03:56 PM   #9
hms2488485
hms2488485's Avatar
Drives: '17 Camaro SS 1LE
It's done it to me too
hms2488485 is offline   Reply With Quote
Old 02-17-2020, 03:00 PM   #10
Bilicki66
Drives: 2018 Camaro 2SS 1LE
Rev match
Interesting, prior to getting motor work done I never had an issue. Now that I got heads, cam MSD intake manifold TB my rev match seems to kick off for no reason. Turn off the car a couple times and the rev match comes back on.
It’s bugging me so bad!!!!
Bilicki66 is offline   Reply With Quote
Old 02-17-2020, 06:17 PM   #11
MTM
Drives: 2019 Camaro SS 1LE
Per the SS manual, ARM will only match the engine speed up to 5400 RPM. I believe this is true for the ZL1 as well.
MTM is offline   Reply With Quote
