02-22-2020, 08:27 AM | #15 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
05-02-2020, 01:35 PM | #16 |
Drives: 2017 Camaro 2SS (Summit White) Join Date: Apr 2018
Is FE4 for 1LEs? I have a 2SS without MRC. I just got coilovers and I need a wheel aligment
06-26-2020, 12:54 AM | #17 |
Amos6.2Jr
Drives: 21 A10 2SS 1LE Join Date: Apr 2017
06-29-2020, 12:17 PM | #18 |
Drives: 2017 Camaro 1SS Convertable Red Hot Join Date: Jun 2018
Just had my 2017 1SS aligned and I am questioning the alignment I was given but I am not completely solid on alignments. Can you smarter people take a look and tell me if I got hosed?
https://imgur.com/a/EmQfkDJ |
06-29-2020, 05:36 PM | #19 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
Everything is obviously green, but none of the numbers are what I would want to see. Front camber is kind of weak if you plan on tracking the car, not bad if strictly street driven. Rear camber is unequal, with the left matching the front, and the right being where you would want it to be to match the weak front camber. It's almost out of spec side to side, should be less than 0.5º difference between sides and you are right there. Notice the gray -0.4º box between the two measurements, not the green box like the front. Front toe sloppy and unequal, rear toe even worse. Ever so slight dog track. Front camber is workable if used on the street, but I'd have the left rear camber brought to match the right rear, and get both front and rear toe fixed.
'18 1SS 1LE Black, PDR
06-30-2020, 01:56 PM | #20 |
That is what I thought when I looked at the sheet! Thanks for the info boost, guess I will be finding a different shop to correct this. I have a track event on Sunday and I really don't want to have tire issues going into a hard turn at speed!
06-30-2020, 03:18 PM | #21 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Also, for track use, I suggest getting the track alignment for at least the LS/LT 1LE since that's nearly the suspension setup you have. Track alignment specs are on page 21 of GM's high performance supplement here
2017 SS 1LE.
