09-19-2016, 11:05 AM | #15 | |
Drives: 16' 2SS M6 Join Date: Feb 2010
I also checked the spot afterwards for any signs of flexing, etc and it was solid |
09-22-2016, 02:15 PM | #16 |
Hopefully this gives a better idea of the stance - Here's a couple more pics
09-22-2016, 02:26 PM | #17 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
09-22-2016, 04:15 PM | #18 |
i love my zl1addons magpuck and jack adapter! i also have the license plate bracket and tow hook adapter for car shows/race track
09-22-2016, 05:32 PM | #19 |
02-09-2017, 11:37 AM | #20 |
Drives: 2017 Chevrolet Camaro 2SS 6MT Join Date: Feb 2017
Your stance looks just perfect! I would really like to add these spacers but have read mixed reviews about going any thicker than 5mm since the wheel won't be sitting in the hub no more. Have you had any issues since?
02-09-2017, 12:37 PM | #21 | |
SABIO
So your wheel will fit perfect, just like stock. You can get them custom made to fit other hub diameters too if you feel like buying a wheel that has a different hub. Such as a BMW fitment.
02-09-2017, 02:01 PM | #22 |
I notice that threads of the original lugs protrude beyond the flat of the spacer. Is there any possibility that the wheel will ride or interfere with those? Or does the flat on the wheel have recesses where those lugs protrude?
02-09-2017, 02:10 PM | #23 |
02-09-2017, 02:11 PM | #24 | |
02-21-2020, 10:18 PM | #25 |
Drives: 2016 Chevy Camaro 1SS Join Date: Feb 2020
I recently installed some 25mm spacers under my stock rims but had rubbing issues with front tires. Anyone else have this problem?
02-21-2020, 10:55 PM | #26 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Better be sure and measure!!! it will bolt up just fine it seems but in a while it will come loose. So just be sure some stock wheels have a hole in the back of the wheel some dontI used 20 mil and had to trim about 12mil of the stud and my wheels had holes in them.
Also after you lock tight and toqure it should not be retightent as it breaks the lock tight but I doubt it will be a problem. Not tring to be bossey just shareing my experience |
