09-18-2018, 09:07 AM | #1 |
Camaro SS 1LE brakes suck (change my mind)
Good morning Al,
I just had my first track day with the SS 1LE Camaro! Everything was great except the brake temperatures. I boiled the brake fluid (Motul RBF600) ----------------------------------------------------- '18 Camaro
And it STILL boiled the racing brake fluid (I exited the main straight @ 60mph into the grass). ----------------------------------------------------- So i come to you looking for recommendations. Thank you kindly, ~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
09-18-2018, 05:47 PM | #2 |
sounds like your too hard on the brakes or you need to try the stock pads again
09-18-2018, 06:57 PM | #3 |
Drives: 2018 SS Join Date: Jun 2018
Less brake, more gas.
09-18-2018, 07:51 PM | #4 |
Drives: '17 ZL1 Join Date: Jul 2016
Are you sure all of the cooling ducts are in place? Something doesn't sound right...
Maybe the bleed didn't get all the DOT3 out? Did you bleed both the inner and outer of each caliper? Maybe different pads and Castol SRF?
09-19-2018, 06:18 AM | #5 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
You're experience is the exception not the rule.
09-19-2018, 11:31 PM | #6 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
I'm guessing you had some stickier tires than stock as well as the race brakes.
If that's true, you are asking a brake cooling system that was designed for stock tires and pads to handle race brakes and maybe slicks or something like a cup tire? Not surprising they would fade. Either upgrade the brake cooling or go back to stock, the car should do just fine with proper brake burnishing. |
09-21-2018, 08:21 AM | #7 | |
Tires are OEM Goodyear Supercar3 HP = Stock Fluid = Motul RBF600 Pads = Raybestos ST-43 I upgraded the fluid and pads... thought those 2 things sorta go together.
09-21-2018, 08:34 AM | #8 |
Drives: 2018 Hyper Blue 2SS convertible Join Date: Aug 2017
if you didn't disassemble the entire system and drain all the dot3 you have a bad mix of fluids.
2018 HBM 2SS CONVERTIBLE A8 |
09-21-2018, 08:38 AM | #9 |
The Raybestos ST43 pads are the reason. I run them on my Gen 5 1LE. You cannot expect “stock like” brake temps when using full race pads. While the OEM air management does a fine job cooling the brake rotors, the calipers will still see the higher temps.
09-21-2018, 08:49 AM | #10 |
Daily Driven 1LE
Drives: 2018 1SS 1LE Join Date: May 2018
This issue is certainly an operator head space and timing issue.
2018 1SS 1LE
09-21-2018, 09:16 AM | #11 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
This is operator error, nothing to do with the car.
You need to manage your brakes. They will get hot and possibly boil fluid and or have pad overheating and that is something that you need to manage. The brake pedal is not an on off switch. I also recommend to use better brake fluid such as Endless RF-650 ,Castrol SRF, or Brembo HCT64 |
09-21-2018, 11:08 AM | #12 |
What track did this happen at?
09-21-2018, 12:43 PM | #13 |
Autobahn Country Club - Full 3.56 mi 21 turns
09-21-2018, 01:17 PM | #14 |
No brake problems with stock pads and SRF and braking at COTA from 140+ mph, 5 sessions per day
