05-04-2023, 11:26 PM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
What to tell shop installing my Headers?
I heard there is a wiring issue and the passenger side coolant wires will melt if not dealt with correctly. How. Should I tell the shop to deal with this? Also are there any other things to look out for when installing long tubes?
05-05-2023, 03:29 PM | #2 |
Tell them to move that harness behind the coolant tank, wrap as needed and zip tie the harness so it can’t sag later. They will most likely move or remove the coolant tank to do the header install.
There are a few lines I wrapped in the area of the collector. Also, have them check clearance of the steering wheel shaft. I’ll also mention to keep an eye out for any oil that may leak at the oil fill dipstick if they don’t seat it properly.
05-05-2023, 04:02 PM | #3 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Great advice... I also applied heat wrap to a few other lines near by... Are your headers coated?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
05-06-2023, 03:23 AM | #4 |
Drives: Chevy Camaro Join Date: Apr 2020
A good performance shop that knows what they are doing will know the ins and outs of putting headers on a camaro by now. The 6th gen is 8 years old. If they don’t I would be looking for a new shop as they probably have no idea how re tune the car for the headers they have never done. Headers are a super simple install.
