Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 09-23-2020, 05:03 PM   #1
TuneAFish
TuneAFish's Avatar
Drives: 2015 Camaro SS M6
Custom track-only tune?
Just curious, does anyone use a 'track-only' tune for race days?
-Rad Air CAI
-GPI SS3 Cam & BTR Springs
-2" Texas Speed Headers
-AEM Wideband AFR
-3" Full Exhaust w/Hi-Flow Cats & Single Chamber Flowmasters
-McLeod RXT twin-disc w/Aluminum Flywheel
-Yukon 4.11
-Nitto 555 G2
TuneAFish is offline   Reply With Quote
Old 09-23-2020, 05:21 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
I used to. Had an EFILive handheld to swap between tunes.
Vegas Bound is offline   Reply With Quote
Old 09-23-2020, 05:38 PM   #3
TuneAFish
TuneAFish's Avatar
I've got HPTuners, that's what brought up the question. I'm curious, what did you change between the two? Just in general terms, not necessarily specifics as I understand they depend entirely on your specific engine and the environmental variables.
-Rad Air CAI
-AEM Wideband AFR
-Yukon 4.11
-Nitto 555 G2
Old 09-23-2020, 10:00 PM   #4
Vegas Bound
Pump gas tune vs race gas tune.
Old 10-15-2020, 02:04 AM   #5
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
It's a big secret, that everyone on here and the other forums won't tell anyone. I know some guys are playing with timing on launch in order to prevent spinning and some other tricks with torque management.
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 10-15-2020, 01:08 PM   #6
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
My car doesn't fit on my tuners hub dyno, but he also owns the local racetrack ( six sigma tuning & marion County raceway). My car is 100% track tuned
If you're a turbo car like myself, its faster to pull timing and put it back in than pull boost and try to build it again.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 10-20-2020, 11:39 PM   #7
TuneAFish
TuneAFish's Avatar
Yeah, I'm just getting started learning my way around HP Tuners; I've got a lot to read before I actually change anything outside of fan temp, idle speeds, and gear ratios. Although I did disable the skip shift, so that was my first big tune item to make sure I didn't break anything :-)
I've lived around here all my life and never knew there was a track in Marion. I've been to Norwalk, 42, Quaker City, and National Trail. Time to add a new one!
-Rad Air CAI
-AEM Wideband AFR
-Yukon 4.11
-Nitto 555 G2
Old 10-21-2020, 05:52 AM   #8
ttshovel
ttshovel's Avatar
Shoot me a message when you go and we can meet up at the track
