Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Autos For Sale / Wanted
Old 03-08-2020, 02:54 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
1000hp Newly Built 2011 2SS/RS
I have decided to put my baby up for sale. Not in any rush to sell but ready to let her go to someone who will enjoy her as I simply have no time as my wife and I plan on starting a family. Vehicle is a 2011 Chevrolet Camaro 2SS/RS and currently has 62k Chassis miles and roughly 800 on the new complete build.. The Car was just wrapped about a week ago in a beautiful Satin Pearl White which came out phenomenal. I will include pictures from before the wrap as well as current.
The vehicle is a true complete max effort application and just received a brand new overhaul which consists of an outrageously built motor which was built by James mullinex out of simi valley,CA. The trans was built by a reputable local shop here in orange county and the rest of the driveline was installed new as was all of the modifications listed below by Mike at Redbarnracing in temecula,CA. Here is a list of the modifications below. I am sure that I have missed a few modifications and I will update as I go through documentation. Only the best fluids were used during the break-in process and it will be receiving fresh fluids (AMSOIL) this weekend.
Asking OBO $38,000 (Over $60k invested so Please do your research before commenting nonsense..Please respect the post)
Power Adder (And a few Misc)
-•Magnuson Heartbeat 2300
-•LSA Accessory 8rib 15lbs of boost
-•Prospeed ZL1 Catch Can
-•Roto-Fab 5'' Air Intake
-•ZL1 OEM Hood And Front Bumper (As well as OEM Hood)
Engine Build
-•LSR Short block LSR-SD2X
-•AFR Mongoose Heads Upgraded Exhaust Valve to Inconell
-•Callie’s Dragon Slayer Crank
-•Callie’s Ultra I beam Rods
-•Weisco pistons
-•Weisco Piston wrist pin upgrade
-•BTR Stage 4 PD Cam
-•Johnson Lifters 2116LSR
-•Moroso Copo Oil pan
-•ARP Main Studs
-•ARP 6 bolt Head Studs
-•Cometic Head Gasket
-•C5-R timing chain
-•Clevite Main Bearing
-•Clevite Rod Bearings
-•ACDELCO Header Gaskets
-•NGKTR8IX spark plugs
Cooling
-•AFCO race radiator
-•Prospeed ZL1 Heat exchanger upgraded to 1” Lines
-•Stewart EMP Heat exchanger pump
-•Rotofab Reservoir
Fueling
-•Fore L4 Tripple system
-Primary pump is a 450
-Secondary pumps are 525's
-•LSA/LS9 Fore Fuel rails
-•-10 feed and return lines
-•Injector Dynamics 1700's
-•Flex Fuel sensor
Exhaust
-•American Racing 2” long tubes (Coated by Jethot)
-•Corsa ZL1 Catback Exhaust (Black Chrome Tip's)
-•Solo Performance resonators
-•Loud Valve Cutouts (Controlable)
Driveline
-•MGW Short Throw Shifter
-•Mcloed Twin Disk 1000hp clutch
-•Built TR6060
-•Speed Bleeder
-•Braided Clutch Line
-•Drive Shaft Shop One Piece Driveshaft
-•ZL1 Rear differential
-•Drive Shaft Shop 1400+ Half shafts
-•ZL1 Wheel hubs
Suspension/Brakes/Wheels/Tires
-•KW Variant 1 Coilovers
-•BMR ANTI Roll Bar
-•BMR Front Sway Bar
-•BMR Trailing arms
-•BMR Outer Trailing Arm Bushing
-•BMR Front end links
-•BMR Upper Control Arm Bushings
-•Pegasus Solid Subframe Mounts
-•Carlyle 15'' Conversion
-•Powdercoated OEM ZL1 Wheels (Wrapped in ToyoR888r's)
-•Beadlock Weld S71 15'' Ceramic Coated Wheels (Wrapped in MT ET Street pro 275/60/15)
-•Custom Powdercoated Front Calipers (Candy apple red)
-•Front Pads are Hawk, Rotors are Slotted Stoptech Cryotreated
Nighthawk89 is offline   Reply With Quote
Old 06-10-2020, 08:30 PM   #2
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Any videos?
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 06-11-2020, 08:32 AM   #3
Nighthawk89
Car Sold. Thanks for your interest!
Old 06-20-2020, 10:32 AM   #4
Tonka1
Drives: Camaro
Great car thanks
Tonka1 is offline   Reply With Quote
Old 06-20-2020, 11:13 AM   #5
mpsgolf
mpsgolf's Avatar
Dayum! Fine ride well done.
2012 Camaro SS Transformer
