07-18-2018, 08:28 PM | #99 |
Drives: 2018 ZL1 1LE Join Date: Jan 2018
WTF! I will check with my dealer when I get the car.
07-19-2018, 08:49 AM | #100 | |
Thank you My hesitation is with lifting this car and putting it on jack stands....I have one ZL1 add-ons hockey puck to use and I'm still unsure where to safely place the jackstands on this car while I jack it up from the side...I need to read more about it.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
07-19-2018, 10:19 AM | #101 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Jacking up the car is definitely the hardest part of the job.
Put the jack in the middle jacking point (there are three slots on the side skirts in each side of the car). If you jack the car up from the middle one it will raise both front and rear wheels off the ground. Once one side of the car is up in the air, place your jack stand near the rear pinch weld (rear jacking spot). Lower the car and go do the other side. That should be the safest way to do it without damaging anything on the underbody.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
07-19-2018, 10:53 AM | #102 | |
07-19-2018, 11:21 AM | #103 |
You can also put a jack under the rear diff which makes it really easy for just lifting up the rear end. Jack the diff + place 1 jack on each side on the rear pinch weld locations with one of the lifting pad tools. Don't jack anywhere else. If you're using a 4 point lift you can get away with some of the lifting points elsewhere. But if jacking, your only options are the pinch welds.
07-19-2018, 03:09 PM | #104 | |
07-20-2018, 07:28 AM | #105 | |
07-26-2018, 11:43 AM | #106 |
Drives: 2018 ZL1 Garnet Metallic A10 Join Date: Feb 2016
Does anyone know a ballpark cost for the differential service?
Dealer ordered the new oil cap today, getting my 1500 mile oil change and diff fluid change on Saturday. Once those are done I should be ready to take it to the local dragway! My dealer has been very helpful and accomodating with the change to the 0-40 oil but I think I'll be doing the oil changes myself in the future.
Buck
"I don't anymore, but I ustacould!" 2018 ZL1 Garnet Metallic |
07-26-2018, 12:51 PM | #107 | |
07-26-2018, 01:11 PM | #108 | |
Buck
07-26-2018, 01:35 PM | #109 | |
$58 for the fluid from the original dealer that wouldn't do the work. 2 quarts of fluid, can be found online much cheaper from quick searching.
08-01-2018, 08:29 PM | #110 |
Drives: Which one? Join Date: Jul 2018
Where in the owners manual do I find these prescribed 500/1500 mile oil changes(zle)? I cant find it!
08-03-2018, 12:31 PM | #111 |
Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Look in the break in section. There is also a performance supplement.
08-04-2018, 11:08 AM | #112 | |
Drives: 2017 1LE Join Date: Nov 2017
Chris.
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
