06-12-2018, 04:39 PM | #1 |
Drives: '18 SS 1LE M6 Join Date: Feb 2018
Nitrous + VVT3 Cam
Soon i'll be getting this cam put in along with having the heads ported & polished, afm deleted, new springs, lifters, rocker arms, etc.
Within a year I plan on wiring up a 75 shot with a plate. My question is how will this cam behave with spray and has anyone run this combo? Cam Specs: 235/239, .645"/.635", 116 LSA +32% fuel lobe. I believe this comes out to +5 degrees of overlap, on stock lift(I think). Will this extra overlap cause a problem, would I be far better off waiting for a custom grind nitrous cam, or just use spray and not touch the cam?
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
06-12-2018, 04:57 PM | #2 |
Drives: 2013 SS Join Date: May 2013
For a 75 shot it's ok. IMO it's a little high on the exhaust side knowing these heads are not as good as the LS one. Custom one would be best. Working on one that's getting a 250 shot soon.
06-12-2018, 05:40 PM | #3 | |
So I guess i'd have to go with a custom grind & better head studs. Which brings me to my 2nd question. With a cam, P&P heads, & 75shot wouldn't that put me around 600whp, which is pushing the limit of the stock pistons, correct? Is that 250shot gonna be on a stock SB?
06-12-2018, 05:59 PM | #4 | |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
06-13-2018, 11:04 AM | #5 | |
Links to the H/C combos or builds?
06-13-2018, 11:47 AM | #6 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
Pray has gotten incredibly close on H/C/I A8 cars. I suspect that if a M6 guy did the same exact stuff, he'd eclipse 600whp. I would think on a more aggressive cam setup, a lighter weight flywheel, E85, etc., on an M6, combined with a solid H/C/I setup, you'd be able to get past 600 without much of an issue.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
06-13-2018, 11:50 AM | #7 | |
BAMF SS
582/518 but through an A8. obviously would be over 600 in a m6 |
06-13-2018, 12:23 PM | #8 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
They say the heads are worse but I’ve never seen a ported stock head and cam SBE ls3 make 600 rwhp with pump E85. It seems like the lt1 is out powering the ls3 quite handily across the board when na apples to apples. And the lt1 is just a baby compared to the ls3. Will probably be hitting 650 when it’s as old as the ls3 and a lot more head and cam options are around
06-13-2018, 02:11 PM | #9 |
Only set back on the LS3s are port injection vs the LT1 Direct injection. If there are better heads for the LTs I think they will be even more great. LT heads are poor quality and core shifts are worst we have seen. Lt4 castings are a little better. I'l post some pics to why we think a better design would make more power.
06-13-2018, 02:14 PM | #10 |
LT1 vs LS3 valve locations were flipped
06-13-2018, 02:16 PM | #11 |
06-13-2018, 02:17 PM | #12 |
06-13-2018, 02:20 PM | #13 |
06-13-2018, 02:21 PM | #14 |
LS heads flow more and better design overall
