Old 12-26-2017, 11:14 PM   #15
TenSeven
Drives: 2016 Camaro SS
I had a problem very similar to this. Make sure your new TPMS sensors are the right part #:
Valve Stem / Sending Unit Part #: 13598787
Nuts Part #: 13507403
TenSeven is offline   Reply With Quote
Old 12-28-2017, 07:33 PM   #16
phaze_1le
phaze_1le's Avatar
Drives: 2018 Camaro 1SS 1LE
Bring it to a Chevy dealer and have them reset them.
phaze_1le is offline   Reply With Quote
Old 06-27-2022, 03:24 PM   #17
Mlevent
Drives: Camaro 2SS 2018
Gist of all from reset option you must reset the sensors, most probably while they were changing the tires, they have taken them abit far from car and it lost connection to car and re-reading only happens with relearn system with a tool. If with relearn system with tool does not work, do not throw your old original sensors, just open them and take CR2032 battery ( suggest duracell) take out the old battery and put the new one and drive few more years, when ever battery finishes you can make the same, but relearn tool is required.
Mlevent is offline   Reply With Quote
