08-11-2018, 01:42 PM | #1 |
SNSTRSS
GM Exhaust sealant
I recently separated primary and secondary cats from the LT1. The connection point to the second cat had a flexible gasket that looked like permatex. Does anyone know the part number GM uses for this. It looks to be designed to seal the 2 cats with the band in place.
2016 Black Camaro 2SS A8 NP
08-11-2018, 04:25 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
I asked the same question, cause the GM stuff works, never got an answer.
08-11-2018, 09:06 PM | #3 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
gm #12378521 sealant
08-11-2018, 09:48 PM | #4 |
SNSTRSS
I believe this is sealant for oil pans and gasket replacement but not exhaust. I can't find anywhere it mentions temperature rating. The gasket like piece did not look just like a sealant only. It looked to have aluminum and sealant as one piece. Thanks for the part number.
08-12-2018, 12:15 AM | #5 |
you talking about the gasket on the drivers side pipe. If yours was sealant then its been apart befor. it supposed to be a metal gasket.
08-12-2018, 08:45 AM | #6 |
SNSTRSS
Jcunningham. I'm not talking about that gasket. It goes around the connection joint of the primary and secondary cats, under the band clamp. It looks like they put it there to seal up the gap. I'm trying to see if I can find what it looked like to show a picture.
08-12-2018, 09:52 AM | #7 |
Mine, after 4000 miles was still wet/elastic. If formed a great seal. I say it is proof positive that aliens are here and evidently work at GM. I would like to use it again on my band clamps and slip joints..
something like this: http://www.aircraftspruce.com/catalo...rmatexprod.php " High Temperature Gasket Sealant is a slow drying viscous paste. It remains pliable and flexible and is designed to seal flanges, threaded connections and fasteners at temperatures from -45° C to +315 "
08-12-2018, 02:53 PM | #8 | |
SNSTRSS
08-12-2018, 03:45 PM | #9 |
Drives: '17 2SS H50 Join Date: Mar 2016
This what your talking about?
Heath
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
08-12-2018, 03:52 PM | #10 |
SNSTRSS
That is it. You are the man. Now just need to find out part number. Thanks
08-12-2018, 03:59 PM | #11 | |
Sorry I dont know a part number. Heath
08-12-2018, 05:18 PM | #12 |
Drives: 2016 2SS Convertible Join Date: May 2012
Unfortunately the factory service manual seems to show that as a single part for the clamp and gasket (#5) if this is the part you're looking for. The repair procedure is to discard and replace with a new clamp. The clamp was around $80 on the web site I checked.
Catalytic Converter Clamp - GM (22860193) |
08-12-2018, 05:34 PM | #13 | |
Heath
08-12-2018, 06:32 PM | #14 |
SNSTRSS
Well that stinks. I just want the gasket.
