01-23-2019, 09:13 PM | #1 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Ceramic Coatings
Is there really a good way to find out if a car does in fact have a Ceramic Coating. My car was purchased used and not really very clean when I took delivery, but after one wash, the paint was quite reflective. The first time I took it to Cars and Coffee, I had several guys ask if it had Ceramic. Although it didn't have many miles on it , the previous owner did take the time to have it protected with a vinyl wrap. So I was thinking that he might have done a coating first. Thx!
01-23-2019, 11:53 PM | #2 |
Pour or spray water down the fender, you should see it flow down almost completely, with the remaining little amount of water beading up into big balls that you can then blow off easily.
01-24-2019, 09:30 AM | #3 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Yeah but if it does bead up like that, could also be some sort of polymer or silica sealant instead.
01-24-2019, 10:29 AM | #4 |
Drives: 2017 Camaro SS 1970 chevelle SS Join Date: Oct 2016
01-24-2019, 04:48 PM | #5 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Only with a Dry Films Thickness meter.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
01-24-2019, 05:06 PM | #6 |
ceramic coat ftw! i had mine done with ceramic pro few months after i got it best $$ i ever spent
have had so many people ask me what wax i use and im like uhh none? lol
01-24-2019, 05:25 PM | #7 |
Yes don't use any other protection like wash & wax, spray wax, etc for 6 months and see how the beading compares to current beading. If there's no change, wait another 6 months. If it is still beading, likely ceramic coated. If it is sheeting off, likely was a polymer.
01-24-2019, 06:24 PM | #8 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Consider this... I did Ceramic Pro with the 5 year guarantee and it was really expensive, like $2K if I remember right. But that 5 year guarantee ONLY applies IF you do a touch up "re-start" every 6 mths, for a cost of about $150. If I have to spend that amount every 6 mths anyways, why not get a Polymer polish (those last 6 mths) and just do that every 6 mths and still get the protection. While it may be marginally better that a polish, most quality polishes will protect for 6 mths, I used Zaino for years and had no issues. I do believe in clear bra the front, but I don't think I will go the Ceramic Coating route next time around.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
01-24-2019, 06:29 PM | #9 | |
Ceramic Coatings
Ceramic pro is a bit controversial in the detailing world. Some love it others say it’s overpriced for what you get. Personally I applied carpro cquartz to both my vehicles and although I use reload on it once a month or so, it seems to be going strong after more than a year. I live in Florida so it doesn’t see a harsh winter by any Means. Applied cquartz October 2017 to my truck and march 2018 on my Camaro. Sent from my iPhone using Tapatalk
2017 camaro SS A8
FBO With all porting and tuning done by PRAY |
01-24-2019, 06:54 PM | #10 | |
The problem that I have with ceramic coatings is that they can still get swirls and scratches. Then you have to polish those out and reapply the ceramic, and that can be expensive. Most bottles of coating will coat 3 cars, so you should have extra left in the bottle for this if you DIY. It is cheaper to use silica, polymers or wax.
01-24-2019, 08:50 PM | #11 | |
If you are going to do that kind of "reload" "refresh" every month or six months for that matter, then any good polymer polish will do. At that rate, you can use just about anything and be covered. The draw supposily with Ceramic is it lasts a long time (5 to 20 years based on how many coats you use) and is maintenance free, but if you read the fine print it really isn't and requires the same amount of maintenance as any other product (that is not Ceramic) on the market.
Current:
01-24-2019, 09:15 PM | #12 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Kirk, think I told you once before, you are selling yourself too cheap!!! I do one car a month by word of mouth, full correction, polish, and essence for primer then 2 coats of Cquartz. I get 1100 for a coupe or small 4 door. 1200+ for larger vehicles. RAISE your prices....
ZL1::J-E-T-S JETS JETS JETS |
01-25-2019, 10:27 AM | #13 | |
01-25-2019, 11:29 AM | #14 |
Yeah $500 is low for the amount of work for a full paint correction and coating. I still do some detailing on the side every once in a while, but I refuse to charge that low for that amount of work. Most people will complain about higher prices, but they need to realize the amount of work that goes into it, especially if the vehicle is filthy and needs a heavy washing/cleaning first.
