12-16-2011, 09:52 PM | #1 |
Drives: 2017 Camaro SS Join Date: Sep 2008
Cold room on 2nd floor
Hey,
on the 2nd floor of my parents house there is one room thats very cold hoping u guys have some suggestions on how to warm up the room i took a picture of the bottom of the room its fully insulated don't know about the other walls though Uploaded with ImageShack.us |
12-16-2011, 09:54 PM | #2 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
does it have a heating vent in it? Is the vent covered up? You could always put a space heater in there
12-16-2011, 09:57 PM | #3 |
there is a heat vent in the room and we are using a space heater its really cold in there compared to the rest of the house when the temps go into the negatives
I was thinking about using a vapour barrier to keep the cold air out edit: will there be any downsides of doing this don't want moisture up there |
12-16-2011, 10:05 PM | #4 |
Got two lowes and buy one of those electric heaters for now maybe
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance in bridgewater ma. |
12-16-2011, 10:10 PM | #5 |
12-16-2011, 10:20 PM | #6 |
Commits weekly crime
Best way to warm your room:
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime. |
12-16-2011, 10:23 PM | #7 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
go here and get one of these for your bed......, pick one.....any one.....and you'll be SET!!
http://www.camaro5.com/forums/showthread.php?t=171508
12-16-2011, 10:30 PM | #8 | |
I was going for the humor angle though
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime. Last edited by Steve Dallas; 12-17-2011 at 12:08 AM. |
12-16-2011, 10:40 PM | #9 |
Drives: 2010 Camaro 1LT SIM w/ Carbon Fiber Join Date: Jun 2011
maybe check the attic for insulation above the room. it looks like it may have been a deck previously, in which case they may have just closed it in not worried about the change in temperature for some reason.
12-16-2011, 10:49 PM | #10 |
lol thanks for the laughs guys to bad its my grandparents room and there is a deck beside it so i will go up there and check
Edit: the room also could have been an add on seeing as how one of the support poles is a foot away from the bottom of the stairs pretty sure that doesn't meet code |
12-16-2011, 11:29 PM | #11 |
Drives: Exige, Miata, Ghia Join Date: Jun 2011
Call an exorcist.
12-17-2011, 12:14 AM | #12 |
Drives: 2011 SIM 2SS/RS Vert Join Date: Jul 2011
Likely the room was an addition, as mentioned above. Insulation in the walls and ceiling may not be as robust as the rest of the house. Also, the vent probably was added on after the fact, so the air flow likely isn't as good as the rest of the floor (heat pump not designed to handle the extra square footage and/or ducting/air flow not designed to move the air efficiently to the addition). Since the room is extended out, it has outside exposure not only on one side, but likely three plus the floor itself, giving alot of area for heat transfer/loss to the outside. Thermostat controls are likely in another location on the second floor, one that doesn't lose heat as fast ... the heat shuts off when the temp is reached elsewhere, which isn't warm enough in that room, and then the room loses heat faster as well making it much colder.
One possible way to help mitigate ... close down the vents more through the rest of floor - rooms, hallways, and closets (1/2 way closed, or more later if the desired impact isn't met) but leave the vent in that room wide open. This should restrict the flow of heat somewhat to the rest of the floor and force more warm air flow into that room. The heat will run longer to warm the rest of the upstairs floor before the thermostat recognizes the shutoff temp also adding more heat to that room. |
12-17-2011, 12:22 AM | #13 |
there is a a full bathroom in that room that makes me believe it is not a add on. the room that the thermostat is in is on top of the garage which is not heated. Also i opened the floor beneath the room up and it is fully insulated which makes me to believe the rest of the walls are I will go into the attic tom and check. The insulation has the number 28 on it could that be the R value?
i don't know much about theis kind of stuff trying to learn only 18 right now so sorry if these are dumb questions |
12-17-2011, 12:26 AM | #14 |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
We have an addition built along the same lines as that. I just threw a space heater in there, warms it up pretty fast.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Fastlane Pipeline Cold Air Intake at Phastek Performance | Jason@Phastek | V8 Bolt-Ons & Tunes | 2 | 03-30-2016 07:19 AM |
COLD AIR INDUCTIONS INSTALL/REVIEW | 1969to2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 76 | 06-07-2010 08:52 AM |
333 Ways to get kicked out of Walmart (just funny- do not try this at home) | Abygale | Off-topic Discussions | 47 | 04-28-2010 01:20 AM |
K&N's Short Ram vs. Cold Air System | SamSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 01-18-2010 07:35 AM |
LMR CAI vs Cold Air Induction Inc TEST with RESULTS!! | Late Model Racecraft | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 64 | 01-13-2010 02:33 AM |
