Old 11-15-2020, 11:56 AM   #15
gtfoxy
Drives: '21 Wild Cherry ZL1
It appears you have a dual tip facia, or am I wrong there.
Old 11-15-2020, 12:06 PM   #16
Jaystroh
Jaystroh's Avatar
Drives: Camaro RS 2LT
Yes just installed. That’s the whole reasoning for this quad tip install.
Jaystroh is offline   Reply With Quote
Old 11-15-2020, 02:10 PM   #17
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Originally Posted by Jaystroh View Post
Yea thanks much! I got the single tip s type when I first got the car from a buddy for half price so it’s been on the car since right after I bought it. I installed the quad diffuser Friday so now I’m at this spot with figuring out the quad tips. I love the S type sound the best but don’t want to by another whole exact same system with quad tips. 950.00 bucks and that’s with discount... that would be awesome if you know of a shop or person willing to do some customizing. thanks again
Ok that makes sense. I shot my guy a message and just waiting to hear back. As soon as I get a word back I’ll PM you
Azerlazer26 is offline   Reply With Quote
Old 11-15-2020, 02:23 PM   #18
Jaystroh
Jaystroh's Avatar
Thanks a lot appreciate it!
Old 11-15-2020, 07:28 PM   #19
Zr8000
Drives: Chevy Camaro
What if you put the npp muffler with the quad tip already on it and just put a block off plate over where the valve would. That would give you the quad tip look. I am assuming the actual npp mufflers mount from the same point of the car as a non npp
Zr8000 is offline   Reply With Quote
Old 11-15-2020, 07:37 PM   #20
Zr8000
Looking at bola website the actual quad tipped npp muffler have the pipe on the right moved over more and the second on the left not centered. Where the mufflers you have the Single outlet is in the center of the muffler. I can see why there are fitment issues trying to add those tips. That is going by the not very good pictures
Old 11-16-2020, 01:32 AM   #21
Jaystroh
Jaystroh's Avatar
Yea I guess a schematic is needed for most on here. You can see the spacing from the rear and I posted the length from front to back. hopefully I find a competent shop that can actually fabricate something.
Old 11-16-2020, 05:07 PM   #22
Zr8000
I doubt it can be done with out messing up that muffler. Probably why 2 shops have said no. If you lopped off the centered out let, welded a plate to close the hole, bored a new whole in there you just destroyed the muffler as you blocked off the outlet chamber and drilled into the baffling
Old 11-16-2020, 05:15 PM   #23
Zr8000
You would need to move the outlet over similar to this, probably change the tube bends, and you would get the clearance needed. You would be way better off using a set of auto zone 50 dollar glass packs and your tips vs hacking into a 1000 dollar set of borlas
Old 11-27-2020, 11:10 AM   #24
Jaystroh
Jaystroh's Avatar
Update on the quad tips. All done!!! Finally. Came out great. Wasn’t easy to find someone to do the work. Custom fab shop took care of it. didn’t have to modify anything but the exit pipe and rear hanger. Happy with the result.
Old 11-27-2020, 11:12 AM   #25
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
How much did all that fab work cost?
HCI2000SS is offline   Reply With Quote
Old 11-27-2020, 11:16 AM   #26
gtfoxy
Looks good man!
Old 11-27-2020, 11:31 AM   #27
Jaystroh
Jaystroh's Avatar
150 bucks. It was way less involved then some of the other shops made it sound. It was about an hour worth of work total. Plus some of his materials to change the pipes.
Old 11-27-2020, 11:43 AM   #28
Jaystroh
Jaystroh's Avatar
Thanks alot. Yea I’m happy. looks awesome
