08-30-2020, 11:38 AM | #15 |
Drives: 2017 chev camaro Join Date: Feb 2020
Throttle body from mike at solers may fix it!
08-30-2020, 11:40 AM | #16 |
It did fix mine.
08-30-2020, 12:23 PM | #17 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
08-30-2020, 12:23 PM | #18 |
Manual mode disables AFM.
2016 NFG 1SS A8
08-30-2020, 01:11 PM | #19 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Tony Mamo TB ....
2012 Yukon XL Denali w/ 6.2 AWD |
08-30-2020, 01:18 PM | #20 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
08-30-2020, 04:47 PM | #21 |
Drives: 2019 SS Join Date: Apr 2020
I hate jerky transmissions.
08-30-2020, 09:43 PM | #22 |
Drives: 2016 Nightfall Metallic Grey 2ss Join Date: Oct 2017
Check the transmission fluid level, seems like pump is cavitating or trans is low and is hesitant to build pressure.
08-30-2020, 09:44 PM | #23 |
08-30-2020, 10:47 PM | #24 |
Yes it does. When my car was stock putting the shifter in Manual mode kept it from going into v4.
2016 NFG 1SS A8
08-31-2020, 01:41 AM | #25 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Are you turning off traction control?
08-31-2020, 08:17 PM | #26 | |
Howdy! Pete here...
But I drive in manual mode most of the time and when I do not have my Range AFM device plugged in, it goes to v4 whenever it meets the same throttle parameters as when I'm in drive mode. My car is bone stock.
PnCRedJwl2SS
08-31-2020, 10:17 PM | #27 |
Not a glitch. From manual mode You have to manually down shift once, then up shift and it will not enter V4 until you put the shifter back in drive. There has been several threads on this over the years.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 09-01-2020 at 09:11 AM. |
09-02-2020, 04:45 PM | #28 |
Howdy! Pete here...
Will try it. I downshift manually every time tho. Pretty much never let the car downshift for me.
PnCRedJwl2SS
