05-23-2017, 12:06 PM | #15 |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
Agree with this. The big reason is because the throttle opens too slowly. Porting it would be the way to go if throttle response is all you want. You will keep your warranty and maybe gain a small bit of hp.
05-23-2017, 12:07 PM | #16 |
Car Enthusiast
Drives: 2017 Camaro SS FIFTY Join Date: Jul 2016
My 17 SS does not have a lag, at least when it's on Sport mode. If I switch it to Track, that's when I notice a lag. I also have the 6 speed manual.
2017 SS Camaro FIFTY
6MT, Nav, NPP, Black Bowties, Mishimoto OCC, Skip Shift Eliminator, GM Footwell Lighting, NGM Splash Guards, GM Blackout Tail Lights (SOLD) |
05-23-2017, 12:11 PM | #17 |
Drives: Poop Join Date: Aug 2016
I’m trying to figure out, are ya’ll talking about, lag or modulation? Without being able to alter how quickly the system uses the pixies, there is no way to change system lag. A tune cannot change this.
Everything else is modulation. You can change the way the car feels by reducing pedal modulation via any of the various add on boxes. This is what most people mean when they say they want to reduce the lag. |
05-23-2017, 12:23 PM | #18 | |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
Friggin fun-killing gov. regulations...
05-23-2017, 12:44 PM | #19 | |
Modulation is the control of the throttle body itself. If you want an on/off switch, you need to control modulation...which can be done by any various throttle intercepting devices. This will make the car "feel" faster without actually making it faster. |
05-23-2017, 12:53 PM | #20 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
05-23-2017, 01:06 PM | #21 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Yes you can tune, it is managed in the "Driver Demand" tables in HP Tuners. As said though it isn't a simple table to mess with, it is a torque based table that references RPM and torque values on a "X" and "Y" table.
Be careful though, take it too far as we call "raping the driver demand tables" and the car wont drive for crap. |
05-23-2017, 01:16 PM | #22 | |
The BEAST
05-23-2017, 01:28 PM | #23 | |
05-23-2017, 01:40 PM | #24 | |
The BEAST
and No. The Vitesse just shortens the pedal travel required. I tried one, and it was stupid. I don't want to lose the pedal's range just for a small difference that doesn't even eliminate the issue.
05-23-2017, 02:20 PM | #25 | |
Drives: 21 Bronco Join Date: Jun 2012
05-23-2017, 02:30 PM | #26 |
The BEAST
So they can control your car remotely....
Jk. I don't remember the actual details, but it had to do with safety and fuel economy. I'm sure some googling will yield better answers.
05-23-2017, 02:31 PM | #27 |
Drives: 2017 2SS Hyper Blue Join Date: Dec 2016
What lag, none in my car.
Check out my photo blog: https://ronfromtexas.wordpress.com/
05-23-2017, 02:37 PM | #28 | |
In the Ford world, people use a pedal commander and similar devices that allow you to program the altered throttle curve. You are looking for a device than can take an input and change the output using a variable curve. It sounds like the Vitesse uses a linear map, which would severely decrease modulation. Have you looked into the pedal commander? It's a bit pricey, but I'm fairly certain it allows you to tweak the entire curve. https://www.pedalcommander.com/produ...se-controller/ |
