11-23-2016, 10:29 AM | #15 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Have you considered an ECS kit or even going TwinTurbo? You won't have the heat soak that you have with the top mount blowers.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
11-23-2016, 12:03 PM | #16 |
WILD CANADIAN HEARTBEAT
Drives: 2014 2SS 1LE RS, 2014 ZL1& 2024 ZL1 Join Date: Sep 2014
They are all good choices, I did a bunch of searching and asking questions and I went with the Heartbeat however it was the more expensive route to go at that time. But have never looked back as I love it. Great power. Here is a write if you want to read.
http://www.superchevy.com/how-to/eng...-supercharger/
700/633 91Octane Street Tune=750/670 VP109 Race Tune TVS2300 Heartbeat SC,ADM Dual Fuel Pumps/ Module, BRM lowered 1", performance rotors, hawks pads, SS Braided lines, GT-14cam, 78mm pulley, AR LT Headers, Cat Deletes, Borla S catback, tinted, 1/LE emblems, 65lb Injectors, Elite catch can,dual valve springs, titanium retainers, super conductor wires and insulators, Robo Fab CAI, Oversize intercooler reservoir, Oracle ghost side markers, Black out Bowties & SS,ZL1 splash guards, Michelin PSS. Built and tuned by Davenport Motorsports (WILD1LE)
11-23-2016, 01:09 PM | #17 |
There are a lot of good choices, i was going go with a whipple for my vert originally but ended up going with a tt kit from agp
Cai intake and a few other mods😎
11-23-2016, 01:37 PM | #18 |
Drives: 2010 Camaro SS Join Date: Dec 2006
They are all good options. Throw the Whipple and Kenne Bell big twin screws on your consideration list as well. Throw an AGP Turbo on the list also. Research them and get some prices. They all have their positives, negatives, and place in the Camaro power adder market.
We are actually truly lucky to have so many options as Camaro owners. |
11-23-2016, 10:36 PM | #19 |
Drives: 2015 Camaro 2/SS M6 Join Date: May 2016
I would look no further than ADM Performance's LSA Conversion. I personally delivered my car from Kansas City MO to his shop in TX and Andy put on his stage 3 kit. My car went from 376hp to 665hp! You just cant beat that. And its all factory bolt on!
2015 Camaro 2/SS 820hp supplied by ADM Performance
11-24-2016, 08:51 AM | #20 |
Drives: 2014 SS/RS White Convertible Join Date: Aug 2016
What are the reasons for going with an LSA swap versus a new SLP or Maggie that are all TVS2300's? Is the power gain better with the LSA over the others?
11-24-2016, 09:27 AM | #21 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
LSA is lower price, uses GM parts, and many reviews show ADM has excellent service.
I asked Andy a similar question and he told me a 2300 will have higher peak HP, but the 1.9 LSA will have more torque. Based on the original post it sounds like either supercharger will fit your needs. |
11-27-2016, 05:03 PM | #22 | |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Ditto. ADM is a standard bearer and cream of the crop shop. The LSA kit is an example of their ingenuity. If you don't mind a long read, my build can show the kit install and all that I've done, and I road race it to! Lots of pics and videos... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
11-27-2016, 05:36 PM | #23 | ||
For my money tho, I still love the ECS or TT option.
11-27-2016, 07:14 PM | #24 |
I know SLP will take my tune and modify it (included with kit) for their supercharger. Does ADM do the same? I need the tune done because I do not have a clue adding a s/c to a NA tune.
11-27-2016, 07:16 PM | #25 |
Yes they do, I would contact them.
11-27-2016, 08:09 PM | #26 |
I see you are a 2014... make sure your research and consider blowers that will clear your hood vent. I believe the Heartbeat and Edlebrock will clear. My LSA conversion from ADM clears with a modification to the drip tray.
I wanted a Heartbeat... Research and Price led me to the LSA. Now after having it.... I would do the LSA again in a "Heartbeat!" - My only complaint is I wish it had more supercharger whine! There is essentially no whine, or none that I can hear over the exhaust. I am now a little biased but don't think the LSA can beat. Andy at ADM is the man, great support. He has done so many of these, it is a cookie cutter process that works flawlessly.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
11-28-2016, 05:47 AM | #27 | |
Drives: Anything I want Join Date: Oct 2008
I can get you a quote today if needed. |
12-02-2016, 08:01 PM | #28 |
Drives: 2011 2SS Inferno Orange Join Date: Oct 2013
If the street is what you are after, you will be more than happy with the LSA conversion. You'll own the street. I just finished mine and it is everything I was wanting and more!
2011 Camaro SS
Buckets of money under hood! |
