Old 09-29-2015, 07:22 PM   #15
Trans damm
Drives: Trans am
Originally Posted by Z28sr2fast4yall View Post
This ^^... The trench goes all the way around the center and the hood has a lip that starts the "trench" that runs all the way around the hood... As far as my render... The hood is an exact copy of the lines from the image... if I had connection to wifi where I am, I'd post an image with simple lines from the track images, showing what I'm trying to say. As you can see in trans damm's two pics, the hoods are nothing similar... The z hood is almost like the l88 hood, but more rounded instead of squared...
The front of the Z hood opening comes into a \/ not round like your render. Also I think they are very similar relative to any other hood produced by Gm (ats aside). There not identical I'll give you that but they have a lot of similar design que's. Either way I'm 99% sure it will be carbon. Just hoping exposed center will be an option.
Trans damm is offline   Reply With Quote
Old 09-29-2015, 07:33 PM   #16
Z28sr2fast4yall
Z28sr2fast4yall's Avatar
Drives: 83z,86z,90rs,91rs,92rs,94z,95rs,95z
It doesn't come into a v... It has a slight "tip" to it, but it's mostly round. My render doesn't really show it too much bc of the angle... But these images will. The "outer shell" is round and comes to a small "peak" as seen in image 2 the zero7 vette stingray hood... It's not going to go into a "v" bc that's not how the hood line goes... Image 3 will show hood line to extractor line...
Z28sr2fast4yall is offline   Reply With Quote
Old 09-29-2015, 08:19 PM   #17
Trans damm
Drives: Trans am
Are you not seeing this pic??
Old 09-29-2015, 08:24 PM   #18
Z28sr2fast4yall
You're looking at it at a alternate view... It's not a v... If you look at the front bumper from a side view, looks like it makes a v, but the front is rounded...Correct? It comes to a point, but it's quite round... Here, let me show you in another way...
Old 09-29-2015, 08:27 PM   #19
Z28sr2fast4yall
It only looks like a v bc of the angle you're at... It comes to a point, but that's the center... Then rounds back... It follows the body lines of the hood... I should've done a top view to explain better...
Old 09-29-2015, 08:57 PM   #20
Trans damm
Drives: Trans am
Yeah the point in the center is what's giving me the v image. The camo is def doing its job. Maybe an overhead shot will clarify it but right now I'm not seeing it round like your render and really hope it's not round.
Old 09-30-2015, 06:55 AM   #21
Z28sr2fast4yall
Well it's not really "round" it rounds to a point... It basically follows the lines on the hood... They usually do... So it'll be straight-ish down the side and then round to the point... It'll look good. The hood on my render is really close, for the angle. Never fear, I don't think gm will disappoint on this one...and yes, the camo is doing its job, screwing with everyone's head and eyes...
Old 10-01-2015, 09:01 PM   #22
amerhash28
amerhash28's Avatar
Drives: camaros in his dreams
I have a question in mind but not sure.....I watched the nurburgring video again and I noticed that the zl1 spoiler looks bigger.now I don't know if its just me because of the covered body or you guys think its a different spoiler from the SS too
amerhash28 is offline   Reply With Quote
Old 10-01-2015, 09:25 PM   #23
Z28sr2fast4yall
It's wayyy bigger for sure... Not only you!!!
Old 10-02-2015, 02:52 AM   #24
amerhash28
amerhash28's Avatar
Thats what I was hoping for.it would be great if we could install on a SS.i like where this is going....
Old 10-02-2015, 07:28 AM   #25
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
The images definitely resemble the old Corvette L88 big block style hood from back in the day more and less like the current ZL1, Z06, CTS-V, and ATS-V heat extractor hoods.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 10-02-2015, 04:22 PM   #26
Z28sr2fast4yall
I don't understand how everyone thinks this hood is like the z06 or cts-v.... Those hoods are just dips with grille vents covering the extractor port. This hood clearly has a center section, that appears to be "going into" the lower and side portion of the hood. The lower and sides are almost like wrapping the center section, which is in no way like the cts or z06. They're extractor hoods yes... But that's the only similarity... This is almost like the l88 hood and old bandit trans am hood mixed...
Old 10-02-2015, 08:37 PM   #27
Trans damm
Drives: Trans am
Is this a different car or did someone chop silver rims on it??
Old 10-02-2015, 09:20 PM   #28
fradaj
Drives: RS
L88 hood:
fradaj is offline   Reply With Quote
