Old 08-01-2019, 10:07 PM   #15
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Did you get the extensions? If you didn’t and don’t have the EXT model you won’t be able to lift your Camaro
Sent from my iPad using Tapatalk Pro
Thanks...Have you experienced this, or are you just saying?
From jack point to jack point on my car it's 53" the QJ will work up to 60".
If for whatever reason it does not, I'll just take it back to Costco or see if I can order an extension.
However, I think it'll fit.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 08-03-2019, 06:59 AM   #16
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
In speaking with quickjack and also other owners experience before I bought mine. Look into it. Be careful I haven’t heard of the std models working yet. You don’t need to return just buy the extensions
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 08-03-2019, 08:25 AM   #17
UrbanKnight
Drives: Fastish
You don’t need the Ext, the standard works fine
UrbanKnight is offline   Reply With Quote
Old 08-03-2019, 10:03 AM   #18
Tazz3069
Tazz3069's Avatar
Has anyone have any experience with Max Jax??
https://www.maxjaxusa.com/
Or Lift Stand??
https://myliftstand.com/
I am also looking for something to lift the car for oil changes and general maintenance.
My only Concern with Quick Jack is the stability.
2016 Camaro 2SS "Black Widow"
Tazz3069 is offline   Reply With Quote
Old 08-03-2019, 11:35 AM   #19
UrbanKnight
Drives: Fastish
I had a max jack. It ok. Doesn’t lift high enough to do the work I wanted. I’ll take quickjack over max Jax for oils and such
Old 08-08-2019, 07:42 PM   #20
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I just found out that Home Depot has the Quick Jack BL-7000SLX on sale for $1159.00 and I am getting it for $1205.10 free shipped to the house.
warren3537 is offline   Reply With Quote
Old 02-05-2021, 11:25 AM   #21
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
You do NOT need the extensions.
The standard length works just fine. I've had my QuickJack 2 years now and dozens of times in the air.
There are 3 lift points on each side. It's easy to find the two that line up for lifting.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 02-07-2021, 01:10 PM   #22
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
While this is true, I personally bought the (7000) EXT model since it allowed for lifting from the front-most and rear-most pinch weld cutouts. Overall, I really like the QuickJack setup for all the cars we own (heaviest being a ~4900 lb SUV).
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
