07-26-2019, 11:27 AM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Sep 2018
Oil Meter in Cabin
This is going to sound so stupid. My dealer isn't giving me a solid answer and instead wants me to bring it in which is going to mean I give them money for an answer.
Anyway on to the question. I'm at 1650 miles on my 1SS 1LE and just had the diff fluid change done which was called for at 1500 miles. Prior to this I had my oil changed at 500 miles as recommended. On the way home I was scrolling through the info screen and noticed my oil life was at 11%. It's only been 1100 miles since my last change so I don't know if this is possible or not. My question to the dealer was is the in cabin oil life meter an active gauge or does it need to be reset on every oil change? They couldn't answer so now I leave this question with you gurus of the Camaro world. |
07-26-2019, 11:32 AM | #2 |
Yes, the oil life indicator needs to be reset following an oil change. it is quite easy. Scroll to the oil life display and hold down the SEL button until it resets to 100%.
07-26-2019, 11:42 AM | #3 |
Thank you for confirming. I had never looked into it and the dealer didn't say anything so I assumed it was active and did not need to be reset. I thought to my self there's no way it burned 9 quarts of oil in 1k miles. I'll remember that on the next change. Do you know how many miles the LT1 goes through before it needs an oil change?
07-26-2019, 12:32 PM | #4 |
ive had it happen also went back to the dealer to make sure they actually changed it since they are 99% idiots that work there...my buddy actually used to ask for the old oil filter back to make sure they actually do it because he doesnt trust his dealer at all
07-26-2019, 03:33 PM | #5 | |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
How long ago was the oil change at 500 miles? The oil life monitor also decreases just based on last reset. So even at 0 miles driven, one year later it will hit 0%.
07-26-2019, 05:25 PM | #6 | |
07-26-2019, 05:27 PM | #7 |
Drives: 2016 2SS Convertible Join Date: May 2012
Agreed. It is an oil life monitor. The engine calculates how much "life" there is in the current oil based on time and driving conditions. I get about 7,500 miles between oil changes based on the oil life monitor on mine.
07-26-2019, 08:47 PM | #8 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I usually change it around 5000 when the indicator shows about 30% left.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
07-26-2019, 08:52 PM | #9 |
Drives: 50th Anni.. coming home 11/01 Join Date: Jul 2014
I change my oil every 6 weeks.. maybe 7 - so it isn't an issue
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms. |
07-27-2019, 09:04 AM | #10 |
Drives: 2021 300 Join Date: Jan 2015
Your throwing good oil and money down the drain. With modern Synthetic oil 7500 miles shows no breakdown of the oil at all. In fact most oils are now advertising 1 year oil changes, the oil made today is that good.
07-30-2019, 11:31 PM | #11 |
i got my 2 free oil changes at the dealer. I stood next to the car with the tech and talked to him about the car while he did it. they even let me pull it on the 4 post lift that i told them i wanted it lifted on. i do all my own work but free is free.
07-30-2019, 11:38 PM | #12 |
i can vouch for that. Blackstone labs 7500 on amsoil Zrod on my cammed LS3 and it was like new. I use Signature in my LT1 and that has a 25,000 mile or 1 year change interval with filter at 15,000. I change it every year though. im only at 12,500 miles in 3 summers.
07-31-2019, 12:56 PM | #13 | |
He's already got over 137K miles on it so the frequent oil changes seem about right.
Richard
08-01-2019, 08:47 AM | #14 |
Interesting so it's not an oil meter at all like a dip stick. The stick was odd to read too I've never seen one like it.
