12-10-2017, 01:00 PM | #1 | |
Markoon13
Drives: Camaro 2SS Join Date: Oct 2016
E85/Headers/Tune - VERY Surprised
As the title says, finally got tuned for e85 and long tube headers. Running the EFI flex fuel kit and Kooks 1 7/8 in to MBRP catback exhaust. I am extremely surprised as how much faster the car feels now. I knew it would be 50-60 whp but it makes solid power all the way across the power band.
12-10-2017, 06:11 PM | #2 |
Drives: 2017 Camaro SS M6 Join Date: Apr 2017
Who did your tune!? I only gained about 35-40WHP and have the exact same mods. Unless my E content is really bad lol.
2017 Camaro SS - Kooks Long Tube Headers 1-7/8th - EFI Flex Fuel Kit - Megan Racing Coilovers - FORGESTAR F14's 20x9.5 & 20x11
12-10-2017, 06:51 PM | #3 |
Drives: SS 6 speed of course Join Date: Jan 2016
Tim did mine and I had to get new tires. Michelin pilot sport plus PS4. I can't agree more with the OP, it is crazy all the way from low to top, and tip in.
12-10-2017, 07:29 PM | #4 |
So when you're tuned for E-85 and using the flex fuel sensor does that mean you can only use E-85 now?
12-10-2017, 07:41 PM | #5 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
You can go back and forth. Just mix it right in
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
12-10-2017, 07:55 PM | #6 |
Markoon13
Cunningham Motorsports did. It really depends from dyno to dyno and place to place. It cant' be that because the way they tuned it, they told me that I will get full timing at 50% ethanol so that way it's safe and won't blow the motor lol
12-10-2017, 07:56 PM | #7 |
Markoon13
Ya Dubchitts is correct. With a flex fuel sensor you can do any mixture of e85 and 91. HP will just go up and down depending on what's in the tank.
12-10-2017, 07:56 PM | #8 |
Markoon13
Definitely! I noticed the traction control coming on in 3rd gear on my first pull!
12-10-2017, 08:10 PM | #9 |
Ahh I see! Glad you finally got your headers tuned! Do you feel a difference in the throttle response now from tuned and untuned headers?
12-10-2017, 11:28 PM | #10 |
Markoon13
Not really. There's more power available down low so it may feel that way, but throttle response is about the same.
12-11-2017, 08:17 AM | #11 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I've been running E85 exclusively since installing my flex fuel sensor kit - probably on tank 5 or 6 by now. The car has felt noticeably stronger from the beginning, the difference was not at all subtle and I was very pleased with the butt dyno increase. That being said, I filled up at a different station last week and the car really came alive, I am certain the increase from this tank vs my first several E85 fills was as much or more than when I switched from 93 octane to E85.
I wonder If the alcohol content is fairly consistent for a given station? It would be nice if this were the case but I expect it's just a crap shoot.
Baby Blue
12-11-2017, 11:38 AM | #12 | |
Markoon13
12-11-2017, 07:23 PM | #13 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
Any downside to running e85 in our cars?? Like longevity wise, or damage to fuel system...anything?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
12-11-2017, 08:06 PM | #14 |
Markoon13
None that anyone is aware of. Many Chevy cars can run flex fuel from the factory.
