12-29-2018, 10:42 AM | #1 |
Drives: 2015 camaro 2lt Join Date: Dec 2016
please help me asap tune issue with overkill
So my car is at the speed shop and has been for 4 days and its racking up the hours at 125 a hour. so got a overkill tune and e85 kit and ported intake manifold and spacer. should have been a 2-3 hour job now its a 8 hour job because the pin up connector/ harness wont fit and we can't find the right one. so if anyone knows about this connector and can help me with this tune please help me. I have emailed will multiple times and have gotten nothing so he's costing me more $$$ having shity customer care.
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
12-29-2018, 02:03 PM | #2 |
Shouldn’t the shop be responsible for getting the right connector? I’d simply tell them I’m not paying for your mishaps. You quoted me 2-3 hrs therefore if you couldn’t find right connector? I’m not paying for it to sit it at the shop. Here’s your $375
Life is short, drive it like you stole it! |
12-29-2018, 03:00 PM | #3 | |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Agreed, unless OP supplied the parts. OP - try sharing some pics of the issue, it can only help. |
12-29-2018, 03:11 PM | #4 |
Drives: Camaro Join Date: Oct 2018
When you supply the parts it’s not on the shop
12-29-2018, 04:12 PM | #5 |
I did supply the parts but when you buy it from overkill it should have the correct parts. ill send some pics
12-29-2018, 04:13 PM | #6 |
Chayse,
Attached are the pictures showing the different wire leads. The lead that came with the Overkill harness is not the correct one and will not lock in place. The pinout connector has square leads. image1.jpegimage2.jpeg Michael Koval Wolfpack Speed LLC
12-29-2018, 04:14 PM | #7 |
https://mail.google.com/mail/u/0?ui=...9pzzM&disp=emb
https://mail.google.com/mail/u/0?ui=...2mW9k&disp=emb
12-29-2018, 04:15 PM | #8 |
He went to a bunch of places to find it and got one but it still didn't fit.
12-29-2018, 06:47 PM | #9 |
Drives: 2014 2-SSRS Slushbox Join Date: Sep 2018
That's a shame...receiving the wrong part.
Is the shop charging you $125/hr to chase down a conncector? That just doesn't seem right. |
12-29-2018, 06:55 PM | #10 |
12-29-2018, 08:11 PM | #11 |
Drives: 2013 Camaro 2LS Join Date: Oct 2015
Before anything, do you remember what came in your kit? It should have came with two new fuel lines, a new flex fuel sensor and a wiring harness which includes a "pin" or "exposed wire". If you don't remember what you got, ask the shop or go there and see what they have. All you need are those few parts; the new fuel lines replace the old ones and the harness connects up to one of the coils, while that exposed pin is placed into one ECM pin slot. If you are missing those parts I can see a problem arising, I just don't see how Will would have sent the wrong harness cause he's been sending them out for years. Did you provide the shop with the instructions? My guess is that they're not connecting it to the right thing or are skipping a step possibly. If it is a mistake on Will's end hopefully he can make things right or at least provide information to get the correct part if that's the case.
Here is the write up I followed for mine. Please read through it and share or email it to the shop so they can follow it. Bring in photos as well. https://www.camaro5.com/forums/showthread.php?t=444675 The write up is extremely accurate especially with the color photos. I was able to follow it and do the mod with absolutely no experience, so they should be able to do it no issue assuming they have the right parts. Do not pay the shop for storing the car, but also keep us updated so we can provide further advice if needed.
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
12-29-2018, 09:52 PM | #12 |
The shop says the pin does not fit that one is round and other is square
12-29-2018, 10:04 PM | #13 |
I don’t have an overkill kit but the dsx one. It should be just about the same and just pop in whether it’s circle or square. I’m now more confused
12-29-2018, 10:04 PM | #14 |
I can email you guys pics if you guys want to see, the shop is a very good shop and he does a lot of flex fuel, he seems to know what he's talking about. I gave him all the parts and instructions.
