Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 07-15-2018, 06:54 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Question 2 step launch M6?
Does anyone know if it's possible to slip the clutch off of the line with a 2 step? Installing my CTAP to my Lnc2000 to enable the rev limiter function and was wondering if this was an option for more consistent launches
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 07-15-2018, 09:08 PM   #2
str8wick3d
Drives: 2011 Camaro SS
You can set the ctap to turn off the 2 step after the clutch fully grabs, that way you don't just blow the tires off as soon as you let the clutch off the floor.
str8wick3d is offline   Reply With Quote
