Old 04-29-2018, 02:22 PM   #29
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Originally Posted by mmaattppllaayy View Post
Don’t waste your time with any of those BS extractors. They are not going to work. What you need to do is get a buddy with a welder to come and take a nut that is the same size as the hole. Slowly build weld up until it gets close to flush with the deck surface. Once flush sit the washer over the hole and weld the hell out of it to the weld that you built up. Then most of the time you can take an impact gun and try to buzz the nut off. Don’t use a regular socket wrench you need to use an impact. I have used this method to get broken exhaust manifold bolts out of ls cylinder heads many times.
Also use a mig welder not an arc welder.
Another note. Let the weld cool completely as it will be expanded slightly because of the heat.
you lost me, i read this 3 times and dont understand.
zz430camaro is offline   Reply With Quote
Old 04-29-2018, 02:45 PM   #30
mmaattppllaayy
Drives: '10 Camaro 2SS
Watch this link
https://youtu.be/KbKZgJs5-k8
mmaattppllaayy is offline   Reply With Quote
Old 05-06-2018, 09:36 AM   #31
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
I've got the engine out of the car now. We're going to try and get the bolt out with the engine out with all of you guy's advice. Thanks again.
And btw I pulled my alternator stud out and this happened
Sent from my VS988 using Tapatalk
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 05-06-2018, 09:54 AM   #32
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
wtf dude!?
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 05-06-2018, 10:27 AM   #33
booneSS13
booneSS13's Avatar
Originally Posted by Bo White View Post
wtf dude!?
I know man! I'm praying that the machine shop can weld it back together and my block isn't done for because of that
Romans 5:8
Old 05-06-2018, 11:44 AM   #34
zz430camaro
Drives: 2015 1LE
Is that more damage on top of the brokent bolt?
Old 05-06-2018, 11:51 AM   #35
booneSS13
booneSS13's Avatar
Yes it is unfortunately
Romans 5:8
Old 05-06-2018, 04:59 PM   #36
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
fingers crossed for you buddy.....keep us posted!
peace
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 05-06-2018, 05:59 PM   #37
booneSS13
booneSS13's Avatar
peace
Thanks man I really appreciate it. This thing has been fighting me every step of the way
Romans 5:8
Old 05-06-2018, 06:04 PM   #38
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Jesus man.....have you checked your blood pressure recently. Cause i would be freaaaaaaking out right now.
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 05-06-2018, 06:31 PM   #39
booneSS13
booneSS13's Avatar
lol I think I'm going to make an appointment tomorrow
Romans 5:8
Old 05-06-2018, 06:36 PM   #40
booneSS13
booneSS13's Avatar
And for the grand finale, hopefully anyway. Just a heads up for everyone, NEVER use a hammer anywhere near the block. It's definitely going have to be resurfaced at the machine shop now. This happened when I was tapping my EZ out in and missed since it was at a tricky angle by the firewall and A/C line.
Romans 5:8
Old 05-06-2018, 07:23 PM   #41
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
My man, I appreciate the fact that you are sharing quite a few unfortunate mishaps. Hope it's all behind you!
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 05-06-2018, 10:24 PM   #42
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
After seeing this even I’m going up to 20 milligrams of BP meds.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
